1999 Audi A4th order Trunk Build Video Pg 7
even though nobody cares ill post some more updates.
I started to assemble the box and fiberglass the inside. it was a pain in the ass and i have a lot of resin on my arm but at least the hardest part is done.
I took a picture of the height right now so i can see how much lower it gets with about 400-450 extra pounds in the trunk.
then while i was working i decided i would take a pic of the new toy. can anyone guess what my favorite color combo is?
if you guessed purple and gold then you would be correct!
box assembled before fiberglass
then after fiberglass. i did about 5 layers on the hole in the front corner over the tape and a big piece on the wall behind each speaker cutout because that was the easiest to get to and then a strip down the bottom from front to back
i still need to attach the back piece then finish glassing in the sealed sections and glass in the ported section
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
i wish! im leaving for georgia tomorrow and wont be back til monday so theres not gonna be any progress til i get back. hopefully after that ill get it together quick though!
Build Thread
UBL
1948 Plymouth
I've been out of town so i havent done any work on it but im going home today so maybe ill have some progress tonight, if not ill definitely have some updates tomorrow! :drinks:
Build Thread
UBL
1948 Plymouth
got an update but no pictures today. i painted the back wall black and screwed it in place. Then I drilled the holes for the threaded rods through the baffles. Tomorrow i gotta lay down some resin and maybe some chop mat, cut the threaded rods to the proper length and bolt them in, and then i get to sand!!! <_<
Build Thread
UBL
1948 Plymouth
Got the whole box screwed together and resined!
heres one of the baffles. you can also see the threaded rod on the baffle. i had to put it that high because the stock trunk panels were in the way any lower.
Here's the front view without the port in and of course my camera phone messes up again to make it look like its not straight!
and the back wall from the trunk. this is where the amps will be mounted
Build Thread
UBL
1948 Plymouth
painted the inside of the box white because thats the only color of spray paint i had. i also took out all of the ez-loks that i put in because they were having all kinds of problems and i got tired of trying to get them to work so ill just be using regular wood screws.
and the mb quart amp, kicker kx3 and buss bars installed on the rear panel. i have just enough room for a crescendo bc3500 on the bottom
Build Thread
UBL
1948 Plymouth
got both subs put in and wired and put the custom smiley faced covers on the other two holes
put the port in just to see what it looked like
and got the back seat put back in so it looks like i have a normal car again.
tomorrow im gonna plug the subs into my brothers kx1000 so i can hear what they sound like finally. im probably just gonna hook the subs up to the amp while its in his car because my car isnt running right now and i dont want to drain the battery any more than it already is
Build Thread
UBL
1948 Plymouth
  • Who's Online   0 Members, 0 Anonymous, 1387 Guests (See full list)
