:NeedPics:
I wanna see how bad it is :)8P
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
are you able to get the truck in the air other than ramps or are you crawling on the ground trying to get the shit off?
ok i know the feeling. it sucks, sounds like your just going to have to scrub or you could bring it somewhere that has a lift and they will probably charge you $60 an hour till there done.
gimme a min and ill grab some pics for you. it makes me sad :(
lol, this should be interesting. did you try brakleen? shit's hardcore
never heard of it, but ill check it out if i ever come across it. a few ppl have told me to try purple power as well.
Get you some aircraft cleaner. Shit works wonders, and will get EVERYTHING off. Get you about 7 or 8 cans of the shit, and start covering the undercarrage. I wouldn't do it all at one time, just in spots...spray it on, let it sit for 15-20 mins, and rinse it off. Make sure that you are over some kind of ground that doesn't mind being fucked up visually for a while...grass will have to be replanted, and sidewalk will never come clean. But it works, and its easy to do. Also make sure you grab some cans of undercarrage/bedliner spray also...as this will strip it down to metal.
