cwebbatya Posted June 10, 2011 Report Posted June 10, 2011 Hey guys I'm installing a system in a car I'm building up for shows. I want to run four p2 subs with single amps to each sub. I want four amps mainly for looks in a redesigned fiberglass box. What is a good amp to single a single dvc p2 ?? Quote
Supercharged DCs Posted June 10, 2011 Report Posted June 10, 2011 Punch 200.2 or 200-2 bridged to a 4ohm load for each subwoofer. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
cwebbatya Posted June 10, 2011 Author Report Posted June 10, 2011 You mean 400.2 bridged right... Quote
Guest Posted June 10, 2011 Report Posted June 10, 2011 are the subs dual 2 ohm or dual 4 ohm or what? Quote
Supercharged DCs Posted June 10, 2011 Report Posted June 10, 2011 No, I meant 200.2 bridged. I love those little amps, probably my favorite amplifier I've used. It would power each P2 nicely. You can go with a 400.2 as well. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
cwebbatya Posted June 10, 2011 Author Report Posted June 10, 2011 Which ohms should I buy ?? What Alpine amp would work.. seem to be easier to find used Quote
Supercharged DCs Posted June 10, 2011 Report Posted June 10, 2011 I'd personally stick with RF since your doing this mainly for show. Keeping the same brand is always a plus If you go with the P200.2 or 400.2 and bridge to 4ohm each, you will need 4 DVC 2ohm subwoofers. An Alpine MRP-350 at 2ohm will be perfect for each subwoofer as well. If you go with this amplifier, you will want 4 DVC 4ohm subwoofers. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
cwebbatya Posted June 10, 2011 Author Report Posted June 10, 2011 Aren't all of the single voice coil p2s 4 ohm subs ?? Really appreciate your help. Quote
Autruche Posted June 10, 2011 Report Posted June 10, 2011 I know from personal experience with those subs that they will take about 500RMS each (before rise) if you give them clean signal, any more than that and they bottom out too easily and coils would stink when played under tuning. I'd recommend anything between 400-500 RMS at desired nominal load. You'd probably be better off just getting a single 1.5K - 2K amp though. Also, you'll probably want to get D2 coils. They would work fine if you wanted to do one amp, or 4 amps. If you want to do just 2 amps, then I'd say get D4s, but it's really dependent on what amp(s) you get, as you want to match your VC config to get the lowest safe nominal load possible. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
cwebbatya Posted June 10, 2011 Author Report Posted June 10, 2011 Dude.. did you read my post..... 4 amps to 4 subs Quote
