bumonskateboard6 Posted June 13, 2011 Report Posted June 13, 2011 You can tell if it's a unibody or not does it have a ladder frame under the vehicle that a body is bolted to or is it all the same piece? Chances are if it's a modern car it's a unibody. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
dyablo409 Posted June 13, 2011 Author Report Posted June 13, 2011 You can tell if it's a unibody or not does it have a ladder frame under the vehicle that a body is bolted to or is it all the same piece? Chances are if it's a modern car it's a unibody. i dont know i would have to check but my car is in mexico for the moment when i go back i will check thanks
Autruche Posted June 13, 2011 Report Posted June 13, 2011 I have to do the big 3 on my roommates cobalt which has the battery in the trunk as well, personally I'm going to run positive and negative 1/0 to the rear because I'm pretty sure cobalts are unibody and I'd rather have a great ground instead of a mediocre one. But other cars with batteries in the rear that have actual frames (rather than being a unibody) I dont see why you couldn't just do a ground to the frame in the rear. Actually, you're pretty much always better off doing a direct ground. Pure steel is only as much as 15% as conductive as pure oxygen free copper. Most people that do direct grounds say that they get less voltage drop than being grounded to the frame. Your best be would be a direct ground and grounding to the frame at the same time. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
lgzmax77 Posted June 13, 2011 Report Posted June 13, 2011 ok so whats a ground block? im new at this take a digital multimeter, put it on DC volts, put one lead on where you want to ground it and put 1 lead on the ground of your battery. if it reads more than 0.2 v its a bad ground.
Bacy2k Posted June 13, 2011 Report Posted June 13, 2011 ive got a 2000 lincoln LS. you can just use the factory ground man. i made a ground block in the trunk 2 years ago. just a week ago, i ditched that and just grounded to where the factory originally had the battery grounded. you'll only need about a foot of 0 gauge. but if you would also like to run a ground to the front, it couldnt hurt. im just saying, simply put, you'll be fine with just replacing the factory wire. and the LS's stock wire from the alt is 4 gauge i believe. looks to be slightly smaller, like 6 gauge tho lol Alpine CDA-9886Hertz Mille 3 ways active Hertz SPL Show 8's 2 Audison Voce Quattro's2 DC Audio M2 Level 5 12'sDC Audio 12.0KKnuKonceptz Wiring4 XS Power D3100'sDC Power 390XPSecond Skin Damplifier Pro and Dynamat Xtreme
dyablo409 Posted June 13, 2011 Author Report Posted June 13, 2011 ok so whats a ground block? im new at this take a digital multimeter, put it on DC volts, put one lead on where you want to ground it and put 1 lead on the ground of your battery. if it reads more than 0.2 v its a bad ground. ok i will do that as soon as i get to my car like i said its in mexico and im in TX thanks
dyablo409 Posted June 13, 2011 Author Report Posted June 13, 2011 ok so whats a ground block? im new at this take a digital multimeter, put it on DC volts, put one lead on where you want to ground it and put 1 lead on the ground of your battery. if it reads more than 0.2 v its a bad ground. ok i will do that when i get to my car like i said its in mexico and im in TX so what does it have to read for it to be a good ground?
dyablo409 Posted June 13, 2011 Author Report Posted June 13, 2011 ive got a 2000 lincoln LS. you can just use the factory ground man. i made a ground block in the trunk 2 years ago. just a week ago, i ditched that and just grounded to where the factory originally had the battery grounded. you'll only need about a foot of 0 gauge. but if you would also like to run a ground to the front, it couldnt hurt. im just saying, simply put, you'll be fine with just replacing the factory wire. and the LS's stock wire from the alt is 4 gauge i believe. looks to be slightly smaller, like 6 gauge tho lol ok sounds good to me. but yea im still gonna run both to the front it wont hurt "only my wallet" but it dont matter
