2 Type R 12's, Kx1200.1, enclosure check
white4d96
Looking into building a new box for my Type R 12's. Got a KX1200.1 coming to run them, but right now they're off a KX800.4.
I'm thinking:
15hx18dx36w
3 4" ports at 24" (bent obviously)
Should come out to 3.8@30hz.
Good idea? Bad? I listen to a lot of low stuff so I want to have that bottom end, hence the low tuning.
Too many projects, too little time...
I reran it and got the same as before.
I'm using Torres' box calc if that helps.
Someone on another forum keeps telling me I should go sealed "for the best lows."
36x18x15 = 4.45ft^3 before displacements.
(pi*r^2)24/1728 for each port = ~.2ft^3
times three for three ports - .59ft^3
So right there you're at 3.86ft^3 before sub displacement, which should be in the .1-.12ft^3 range per sub. All in all it looks like 3.6ft^3 with a 33hz tuning.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
I'm a guy that always runs sealed up to the last year and a half and I can tell you that I get much lower being ported.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I running mine in a slightly smaller box than recommended. 1.4 instead of 1.5 NET, tuned at 32Hz and I couldn't be happier, Great response and output plus I can do hair tricks :)
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
I would shoot for something between 35 and 38 hertz.
That seems to be good for both rock and rap IMO.
  • Who's Online   0 Members, 0 Anonymous, 1088 Guests (See full list)
