I was just wondering if I could get some opinions on building a box/box's for 4 08 s12 L5 4ohm subs
Not sure if I should make one large box like 16 cubes, with like 150" port, or make a box with 4 seperate chambers and ports, maybe even 2 boxes with 1 chamber each and 1 port each, I just don't know... please help and give some advise as to what I should go with, any and all boxes are appreciated
Those subs get loud with 2 cubic feet and 4" aero per sub, i haven´t try slot port on them, but i would build something like 8-10 cubic feet and 115-140SQ of port, just saying...
just to post in the more active thread
7ft
100'' of port
tuned to 35 or 32hz
subs up port back
and I actually have experience with kickers l series subs
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
So do i, i got better results wth 2 c/f and single 4" Aero per sub, i´m talking about the L5 , the L7´s well , i don´t have much experience with them, what about those korey? you use bigger port area or what? :drinks:
Thnks for the input. The 10 cubes with 140" of port, would you fire the subs on top and port on side twards the hatch or put port and subs on same side firing twards the hatch? And what would that box be tuned at? 10 cubes might be a hair small unless that's after displacement? And would you happen to have a design for that box?
are you looking for loudness? if so id say 2.25 per sub with 16 sq in per cube port area, tuned to 36-37 off rms power
Subs up port back
It's 10 net
Port is 2cube if u tune @34hz it will b 22long
Just add in any bracing u add to the box
Gross 12.68+ bracing
If you are ever satisfied, sounds like you gave up... Never Satisfied ~Team Ns~
Subs up port back
It's 10 net
48w
17h
33.5d
=13.35cube
Port
151/2 high
91/8 wide
I 45ed the conners and a lil bracing...
