I just recieved my pa a3000db in the mail about 20 mintues ago. wanted to make sure it worked, so i walked out to my car and hooked in my remote line, my battery cable, rcas, and ground...then i go to start up my hu just to make sure the power light comes on. so i start it up and run back to my trunk...i notice that my protect light is on for about 3 seconds and then it switches to normal power light. is this normal ?\
thanks
i know with the ones i had the protect light would come on for a breif second (about 2-3 seconds) and as soon as the internal fan got up to full speed and you could hear it hum the light was off and the green light on,....so next step for you is to connect a sub to it to make sure you didnt get a bad amp to be safe of connect a volt meeter to the amp and see if it is puting out
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
yes it is normal the protection light was on because of low voltage at first start up then it got the voltage level it needed. I have seen amps do this before just the initial power up that is all. shouldn't happen again.
yep only for a few seconds , if it stays on then the amps fucked....
i have a sight delay (2-3 secs.) i think all amps take a sec or so to kick on. my protection light doesnt come on though. its a powerbass xa-3000d :PStereo126.jpg
post some pics bro. heck my amps take a second or so to come on also. what subs do you have?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
my only problem with that a3000db amp is
1) first amp blew up in my face, so I had to buy a second one really fast- returned the first one
2) second one was just plain noisey, like the internal fan has no bearings
but the goods are, great power for the price!!
