1g eclipse gsx street build
Looks like a nice project you got going cant wait to see it done will be watching for vids.
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
Engine
Modification
6 bolt block
6 bolt head
acl tri metal race main and rod barrings
all emissions crap removed or blocked
ams race balance shaft elimenator kit
ARP Harmonic Balancer Bolt
arp head studs
arp main studs
bc 1 mm over valves
bc 272 cams
bc valve springs and retaners
bored .020 over
Cometic head gasket
crower rods
custom brc pistons
Fully balanced internals
gapless rings
greddy timming belt
itm revised lifters
Kiggly Racing 6-Bolt Main Girdle
magnas heat barrier intake gasket
silicone vacumm lines
supertech valve guides
Transmission
Modification
act 2900 street clutch
all new driveshaft universal joints
driveshaft yoke recall kit
Extended Clutch Slave Cylinder Rod
fidanza flywheel
in car solid shifter bushings
new driveshaft carrier barings
new oem pivot ball
new shifter fork
stainless steel braided clutch lines
Brakes
Modification
stainless stell braided lines
Audio
Modification
pheinix gold mids and highs
Intake
Modification
2.5" intercooler pipe
94 throttle body
greddy bof type rs
k&n air filter
Exhaust
Modification
2g ported exman
3" megan racing dp
3" megan racing test pipe
3"megan racing cat back
ported o2 pipe
stainless steal wide band 02 bung
Turbo
Modification
custom adjustable wastgate
oil feedline w15 micron filter stainless steal braided-4an
oil return socketless hose fitting -10an
ported cliped big 16g turbo
push to lock -6an water line
Intercooler
Modification
cx racing fmic
Fuel Delivery
Modification
650cc injectors
aem fuel rail
fuel lab afpr
fuel lab fuel filter
pump rewire
push to lock -4an return line
STM FUEL TANK TO RAIL KIT
walbro 255lph
Engine Management
Modification
2g maf
2g mas adapter wiring harrness
apexi safc2
data logger on a palm
greddy boost controller profec spec b II
greddy full auto turbo timer
stage 3 keydiver chip
Miscellaneous
Modification
cruse control removed
removed all ac
Ignition
Modification
94 cas
95 coils
95 power transistor
ngk plugs
ngk plug wires
Fluids
Modification
BG Syncro Shift II
Diaqueen Transfer Case/Rear Diff. Fluid
dot4 brake fluid
moble1 full synthetic 10w40
Gauges & Sensors
Modification
autometer phantom water temp gauge
autometer phantom boost gauge
autometer phantom egt 0-2000 gauge
autometer phantom oil press gauge
autometer phantom wideband o2 gauge
custom fiberglass vent dual gauge pod
triple a piller gauge pod
future plans is suspension and two sa 8in and a sa1500 for a lil bump without a ton of weight. ill make it easy to remove for track days.
you do realize that the stock rods are good till 700 hp right?
the bigger valves are a waste.
and brian crower is junk.
other than that good job.!
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
