i would try rubbing compound because if u aint careful with the laquer thinner or its a real weak thinner it may dull the paint
But if you ain't careful with compound you'll burn right through the clearcoat.
First off, try claying the car. See if that takes it off. If not, I would start with the finest compound you can get. If it doesn't take it off, try going a little more coarse. BE CAREFUL! If you push too hard, use the wrong kind of rag, or work it in too much, it WILL burn through your clearcoat and you'll be effed. I recommend washing the car right before, then running the hose over the area you are working. I've found it works best if you make a 'slurry' of water and the compound. Also, if you're gonna do it by hand, more power to ya; I would get a buffer. I've never used a cheap one, but if you can, get a good one like a Porter Cable. You have to be a true moron to mess up paint with a PC.
Oh, you could also try a wax and grease remover. See if that takes it off.
burning thru clear with rubbing compound by hand i highly doubt it with a wheel yes be careful i used to detail cars for a living for a few yrs i never scene it happen by hand. Edited by 89boxchevy
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
Meguiars makes a "paint cleaner" that is a step above polish and a step below rubbing compound, if you can find it it's good stuff.
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
clay bar
yeah, a clay bar kit with take it right out, will takes the least amount of time, and work, idk why nobody else said it >.> noobs.
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
  • Who's Online   0 Members, 0 Anonymous, 576 Guests (See full list)
