Hello i am from norway. and i know i do not own a sick system but i like it a lot and still its i progress with front sistem ;)
Ok there it is what i have .
Front door before and after ;)
keeping always ready for bass :D
BIG 3 :)
Compare
after 15w0 i try a 8w3 in sealed box.
And first it was like this
Now many things had change.
Front battery stock for now ;)
Back battery stinger sp 1700, from front 2x50mm2 wires goes to back one straitgh from alt second from front battery.
My amp for my bass :)
And my fi Q 18" i love it!!
Honda CRV 2.0l
Headunit - Pioneer RS 88 II
Front - DLS RM 6.2
Back - empty
Front amp- JL AUDIO HD 600/4
Sub - Fi Q 18" (220ltr ~29hz)
Sub Amp- Cadenze zrs 10 (1000@4ohms. [email protected]@1ohm)
Extra battery back Stinger SP 1700.
And there we go start to bild the box. ;)
Miky mouse :D
I make it ports by me self and me frend. 16cm wide ;)
4x35mm2 for amp to have still power ;)
No 90 deegres corners inside
some help for 22mm MDF to hold the beast :)
First playing the rap :) akon- i wanna f... you ;) its was on @4ohms and 75% gain i let sub to get worm before connecting on @1ohm.but still its bangin alot :)
There is some videos HD ;) just camera take the volume very low because of bass distorsion for the camera... sorryy
it think it is mane pictures from my stereo ;) Now i will upgrade the alternator and the fornt system it going to be 4x 8" midrange 2x6"mid range and 2x3"tweets ;)
Honda CRV 2.0l
Front - DLS RM 6.2
Back - empty
I love Fi Q's man. i bet that sounds great. how did you make those ports?
1996 Buick Lesabre Limited - 2 Fi Q 12's, 5ft^3 slot ported box tuned to 30hz, MMATS 3000.1, JL G4500, 5.25" Polk momo comps, cheap 6x9's (rear fill), Pioneer DEH-P8300UB, Knu wiring throughout, Big 3 all 1/0, stock alt, stock batt, Deka 8a31 in the trunk
---Now gone to the younger brother, and all the equipment is sitting in my garage.
96 Buick Lesabre Build Log
Nice job man, waiting for the new score after you wire that thing @ 1 ohm :)
its just simple tube from drainage. simple cheap to buy easy to work with. i use 2x16cm ports. you make form its like 3 plates one 16,17,18cm when you heatig it up with heating pistol and pushit down it goes to the sides..like i hope you understand.
Ye about @1ohm waiting for 3-5 batteries hawker 12hx300 72ah 3175A Max :) this battery lose to xs power 3100d just a lil bit from 10 spl tests its lose first two tests 0,2db later the same to the end all 8test.
this is a video but in russian but you will se the numbers its gzpa 10000.1 :) each burp its around 4.8kw after 10 burps the voltage drops from 0.1-0.2V :) but the prise is 2x less ;) its ok for me i dont have so much money for xs power 3100d.so will se hot it goes with hawker price 169euro :)
Honda CRV 2.0l
Front - DLS RM 6.2
Back - empty
Looks good mate, but do you still have out gain at 75% like you stated earlier?
Yep. still 75% dont find tame to connect on 1ohm.and now i have just 16cm front sistem from DLS RM 6.2 runing from jl audio hd 600/4 and its quite to much bass for now,so before i get a new front system i dont think i am going to reconnect sub on 1ohm. :S
Honda CRV 2.0l
Front - DLS RM 6.2
Back - empty
How did you set your gain? That could harm the subwoofer...
The amp has nearly 1000rms on 4ohms. i set a gain aroun 75% because i dont want all distrotion go to sub. and for now let him play like this. maybe i did something wrong? i want to give him playe 50hours or some like that then connect 1ohm and give to him 1200-1500rms :)
Honda CRV 2.0l
Front - DLS RM 6.2
Back - empty
