I have two Fi Bl 15's fully loaded in a custom enclosure i built for my car. It is powered by an AQ2200d. Today when i was driving i smelt smoke coming from the trunk. The subs were kind of warm when i got out and felt them and the amp was hot. I have 4 gauge wiring on the amp and only 14 gauge wire for speaker wire.I have not done the big three nor do i have a extra batteries. I have a stock amp. Please help me figure out what caused all this and how to fix it. I talked to a few people who said that i need bigger wire and to do the big 3. Please Help
Your probably clipping it. How was your amp set? Ear, multi meter, O-scope?
Big 3 with Yellow Top
besides the power issue you might have, there are other things to look at. do you have a good, solid ground on your amp?
If the ground is too long, loose, or not anchored tight to bare metal, you can have this happen.
How are your subs wired? If your OHM load is to low, you can have this problem
Is your box built properly? If your port tuning is off, you can tear up your subs.
definately get the big three done asap. Your 4g power wire isn't helping you much, if your factory ground wire at your battery is 8g.
this is just the start
2005 USACi National SQ Points Champion
2008 Top 12 Installer, Mobile Electronics magazine
2009 Top 12 Installer, Mobile Electronics magazine
2010 Top 12 Installer, Mobile Electronics magazine
2012 Top 100 Installer, Mobile Electronics magazine
Tread jack kinda.. How long can the ground on amp be from the battery?
4 gauge.... shit... theres your problem. your amp can only amplify the amount of amps that the power wire carries, regaurdless of gain settings. buy yourself some 1/0 and do yourself a favor.
like said above, what voice coils do your subs have, and give us some info on the box. i could build a custom toilet out of plywood, doesnt mean its gonna work. FI subs hate being tuned low, i have no idea why, something with the kind of suspensions and coils FI uses.
plus, your port could be choking the subs.
you seem to have more money than knowledge, i say just get yourself a deep cycle marine battery and swap it in. you'll be suprised what it can do.
Edited by SkylarDunn
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
The ground needs to be as short as possible.
  • Who's Online   0 Members, 0 Anonymous, 2084 Guests (See full list)
