potatochipd Posted June 22, 2011 Report Share Posted June 22, 2011 I have two Fi Bl 15's fully loaded in a custom enclosure i built for my car. It is powered by an AQ2200d. Today when i was driving i smelt smoke coming from the trunk. The subs were kind of warm when i got out and felt them and the amp was hot. I have 4 gauge wiring on the amp and only 14 gauge wire for speaker wire.I have not done the big three nor do i have a extra batteries. I have a stock amp. Please help me figure out what caused all this and how to fix it. I talked to a few people who said that i need bigger wire and to do the big 3. Please Help Quote Link to comment Share on other sites More sharing options...
blownengine Posted June 22, 2011 Report Share Posted June 22, 2011 Your probably clipping it. How was your amp set? Ear, multi meter, O-scope? Quote 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free) Link to comment Share on other sites More sharing options...
caraudiofreq Posted June 22, 2011 Report Share Posted June 22, 2011 besides the power issue you might have, there are other things to look at. do you have a good, solid ground on your amp? If the ground is too long, loose, or not anchored tight to bare metal, you can have this happen. How are your subs wired? If your OHM load is to low, you can have this problem Is your box built properly? If your port tuning is off, you can tear up your subs. definately get the big three done asap. Your 4g power wire isn't helping you much, if your factory ground wire at your battery is 8g. this is just the start Quote 2005 USACi National SQ Points Champion 2008 Top 12 Installer, Mobile Electronics magazine 2009 Top 12 Installer, Mobile Electronics magazine 2010 Top 12 Installer, Mobile Electronics magazine 2012 Top 100 Installer, Mobile Electronics magazine Link to comment Share on other sites More sharing options...
LoudBimmer Posted June 22, 2011 Report Share Posted June 22, 2011 get atleast 2 gauge wire for power and ground. and it's kind of risky running 2200 watts on stock electrical. Quote Link to comment Share on other sites More sharing options...
Rebel4055 Posted June 22, 2011 Report Share Posted June 22, 2011 Doesn't the AQ2200 require 0 gauge?? Quote Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
dkahns51 Posted June 22, 2011 Report Share Posted June 22, 2011 besides the power issue you might have, there are other things to look at. do you have a good, solid ground on your amp? If the ground is too long, loose, or not anchored tight to bare metal, you can have this happen. How are your subs wired? If your OHM load is to low, you can have this problem Is your box built properly? If your port tuning is off, you can tear up your subs. definately get the big three done asap. Your 4g power wire isn't helping you much, if your factory ground wire at your battery is 8g. this is just the start Tread jack kinda.. How long can the ground on amp be from the battery? Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time Link to comment Share on other sites More sharing options...
Louisiana Bass Posted June 22, 2011 Report Share Posted June 22, 2011 Get 0gauge wire for the power and ground, and turn the gain down. Your amps getting hot because your voltage is dropping like fucking crazy. Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
Rebel4055 Posted June 22, 2011 Report Share Posted June 22, 2011 If you have not a clue on how to set the gains and such and you maxed stuff out, your voltage is dropping like a lead balloon causing your amp to get hot and your subs. Quote Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
SkylarDunn Posted June 22, 2011 Report Share Posted June 22, 2011 (edited) 4 gauge.... shit... theres your problem. your amp can only amplify the amount of amps that the power wire carries, regaurdless of gain settings. buy yourself some 1/0 and do yourself a favor. like said above, what voice coils do your subs have, and give us some info on the box. i could build a custom toilet out of plywood, doesnt mean its gonna work. FI subs hate being tuned low, i have no idea why, something with the kind of suspensions and coils FI uses. plus, your port could be choking the subs. you seem to have more money than knowledge, i say just get yourself a deep cycle marine battery and swap it in. you'll be suprised what it can do. Edited June 22, 2011 by SkylarDunn Quote Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS! Link to comment Share on other sites More sharing options...
caraudiofreq Posted June 23, 2011 Report Share Posted June 23, 2011 besides the power issue you might have, there are other things to look at. do you have a good, solid ground on your amp? If the ground is too long, loose, or not anchored tight to bare metal, you can have this happen. How are your subs wired? If your OHM load is to low, you can have this problem Is your box built properly? If your port tuning is off, you can tear up your subs. definately get the big three done asap. Your 4g power wire isn't helping you much, if your factory ground wire at your battery is 8g. this is just the start Tread jack kinda.. How long can the ground on amp be from the battery? The ground needs to be as short as possible. Quote 2005 USACi National SQ Points Champion 2008 Top 12 Installer, Mobile Electronics magazine 2009 Top 12 Installer, Mobile Electronics magazine 2010 Top 12 Installer, Mobile Electronics magazine 2012 Top 100 Installer, Mobile Electronics magazine Link to comment Share on other sites More sharing options...
