mxman38 Posted June 22, 2011 Report Posted June 22, 2011 Getting bored of my 2 18" BTL's... only have them off of 3500wrms. Dont want to do dual alts so i really cant put much more power too them otherwise i know ppl would tell me to get a bigger amp. My Max dimensions are 24.5 tall, 26 deep and 45 wide. Power is a H/O 250a alt 2 2400's and a yellow top up front, 2 runs of zero. Im thinking maybe 4 10s or 12's if i can fit, but not sure if it will necessarily be louder I want to keep my budget around $1200, any input?
TeamHT Posted June 22, 2011 Report Posted June 22, 2011 You change often and get bored very easily with your setups, lol. What is the enclosure like? Or are you just done with the subs in general. Normally, if a setup does not make me happy, then I try a different enclosure before new subs, but just a thought. Tell me...does this smell like chloroform to you?
mxman38 Posted June 23, 2011 Author Report Posted June 23, 2011 You change often and get bored very easily with your setups, lol. What is the enclosure like? Or are you just done with the subs in general. Normally, if a setup does not make me happy, then I try a different enclosure before new subs, but just a thought. This was the most common enclosure in SUV's that ive seen so i just did 12x12 for the port, its around 31hz I love the lows, but yeah haha i just always want louder for some reason. Im sure i could push more power and be happy, im running my orion around half ohm so its definitely a sweet spot for the amp. x2. boxes are cheaper than subs or amps... yeah i just hate spending another 200 by the time i get glue resin etc. if im not sure of the design
korey_hofer Posted June 23, 2011 Report Posted June 23, 2011 do a better box, 3500 each is plenty 2 18's should be in the 153 range I have no idea what car you have so I can't recommend anything else previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
mxman38 Posted June 23, 2011 Author Report Posted June 23, 2011 do a better box, 3500 each is plenty 2 18's should be in the 153 range I have no idea what car you have so I can't recommend anything else i only have an orion 5000d @ half ohm for the pair... Its a trailblazer ss, maybe i should sell the orion and do a different amp? Or do 4 12's in the same style box off same power?
cubs_fan0718 Posted June 23, 2011 Report Posted June 23, 2011 Heres my suggestions- different box, different amp, bigger alt so u can get a bigger amp. Find a used SAZ4500, or look for DC5K, 2 AQ3500 and strap them , cresendo (sp?) i think it's a 5500, or wait for Sundown 2 come out with the NS1. Is ur box Subs up port back? that generally is the best for SUV's 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017
mxman38 Posted June 23, 2011 Author Report Posted June 23, 2011 yeah its subs up port back, like i said thats how meade ran his and ever one else i know... what alt do you think ill need for a 4500 or 2 3500's?
mxman38 Posted June 25, 2011 Author Report Posted June 25, 2011 i have D1's so what amps would i be able to use? Im thinking 2 aq2200's?
