so i got a 2002 impala and recently my ac, and coolant fans werent coming on causing the car to overheat in stand still traffic. i did alot of research and came up with the bcm needed to be replaced, only after checking relays connections and other miscilanous stuff, so i had a new bcm put in and programmed by a chevy dealer, fixed the problem , everything seems great, started going down the road and my gauges start flipping out on me ,message center says, trunk open , door ajar, low coolant, lights in the car flash on and off, i have removed every single piece of audio equipment, installed a brand new battery, checked all grounds and power leads and still have these issues, so could some one pls help or offer a solution, and if so thanks...
i also talked to dealer and did more research, dealer says without changing every relay and sensor theres no way to pin point the problem, my cars in great shape but the blue book value is right at 2k, i just spent 4 bills on it, so im trying to avoid the dealership could end up spending more than the cars worth and still not get it fixed
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
  • 4 weeks later...
Every time someone comes in and says "this car is acting so weird! gremlins!! WTF!" It is a bad ground connection somewhere. Pull up a wiring diagram for your model and year, find out where the gauges, cluster, whatever else is affected is grounded....and 99/100 times, all of the components that are affected have a common ground connection. I've seen problems like this come down to a loose bolt under the dash. Find that common ground, check the connection :)
**EDIT
I'm referring to FACTORY ground connections, probably a bolt to a support member under the dash, with a large amount of components grounded to it. Just clarifying.
Edited by AlexRhodes
  • 2 months later...
check all the grounds ...also the BCM controls all those things actin up the pcm control's the fans my guess would be that when the installed the new computer they programed something wrong....also i looked on alldata and there is a bulletin about corrosion on the the conctoins and lose plugs ...bad thing is that is is located behind the left instrument panel.....good luck man message me if you need any help and i help u as much as i can
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
