will77530 Posted July 15, 2011 Report Posted July 15, 2011 start off with just the basic wires 12v and ground and speaker wires and see if it does it. start adding wires one at a time until you find which wire is causing the feed back
MustangGT Posted July 15, 2011 Author Report Posted July 15, 2011 Yeah stock audio. After market hu. An a 500/1 with a jl w6v1. does your sub pop too? Yes it does pop.
MustangGT Posted July 15, 2011 Author Report Posted July 15, 2011 start off with just the basic wires 12v and ground and speaker wires and see if it does it. start adding wires one at a time until you find which wire is causing the feed back Thanks. Will do. Hopefully I find the problem.
MustangGT Posted July 24, 2011 Author Report Posted July 24, 2011 I have had no luck finding the problem. Can the power wire be causing the problem..?
MustangGT Posted July 24, 2011 Author Report Posted July 24, 2011 I put back my original hu and I didn't hear the poping any more. Still confused on what was causing the problem.
MustangGT Posted September 7, 2011 Author Report Posted September 7, 2011 I pretty much found my problem. Some cables were probably touching each other. And I now usee butt connectors insted of tape. So far stereo is working great now.
412 CVX Posted September 8, 2011 Report Posted September 8, 2011 nice! Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Rebel4055 Posted September 8, 2011 Report Posted September 8, 2011 Never just use "tape" to secure wiring. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
MustangGT Posted September 10, 2011 Author Report Posted September 10, 2011 Thanks. Lesson well learned.
MustangGT Posted December 21, 2011 Author Report Posted December 21, 2011 So after a long while of having my sub disconnected I finally decided to connect it again. Work good for a while and now I'm getting the loud popping again. I changed the ground of the amp and still no solution. What can be causing this?
