teamace24 Posted June 25, 2011 Report Posted June 25, 2011 I built a dual 15 sub box 7 cubic feet net tuned at 34-35hz. I installed two kicker cvx 15 in the box but they sound like they want more air, it tends to have a fart type sound when playing the higher notes or when i turn the epicenter up for spanish. I have built many boxes and with great results but this is the smallest box i have ever built for two 15 subs, so im guessing this is why they sound like they do not want to go deep and have a fart type sound. Question is since i like the box quality and build, what subs will perform optimally in about 3.5 cubes tuned at 35hz? I have a budget of around $350-400 and 1500 rms total of power, so im looking for the subs to handle 750-1000 rms. Thanks. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
homiewes Posted June 26, 2011 Report Posted June 26, 2011 well you should build the box to the subwoofer specs, sounds like you need to rebuild a box for those subs.. i wouldnt stick any other sub in there.. unless your planning on buying new subs then its worth a try to see if it sounds good. My youtube channel, please subscribehttp://www.youtube.com/ballinblaza
D-train-13k Posted June 26, 2011 Report Posted June 26, 2011 the level 2 15's Might work.. The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
g6ryder Posted June 26, 2011 Report Posted June 26, 2011 well you should build the box to the subwoofer specs, sounds like you need to rebuild a box for those subs.. i wouldnt stick any other sub in there.. unless your planning on buying new subs then its worth a try to see if it sounds good. I agree why wouldn't just scrap the box and build another more close to the specs of the subs u already have a box is much easy/cheaper to replace than a new set of nice subs www.wooferwarehouse.com
teamace24 Posted June 26, 2011 Author Report Posted June 26, 2011 My clarion eq i noticed was at 90hz low pass so i put it to 50hz and it helped a lot with the farting which was mostly there with the higher notes. Ive tweaked everything and im more satisfied overall with the sound it pounds but i think since each sub is getting only 3.5 cubes, songs like killa cam with camron tend to lack a little bass when it hits. I increase the 50hz knob on the eq and it helps a bit but i think overall i should of went atleast 4 cubes each. Does anyone know what hz killa cam by camron has in the song? 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
