Bouoy Posted June 26, 2011 Report Share Posted June 26, 2011 I was sitting in my truck the other day trying to lay everything out. I came up with a idea to try and flush mount the amps in the backs of the front seats under plexi. I wondering if this has been done before or not due to the overheating. I figure I will have to run a cooling system in a box with some vents and a pc fan or two. I figure 2 fans one as a input and the other for output. The amps are PPI ones. This truck will be used as a shop demo truck so I'm going all out with the details for it. Any comments would be welcomed. the truck is a 2011 Toyota Tundra Thanks B Quote Link to comment Share on other sites More sharing options...
3Ltriste13 Posted June 26, 2011 Report Share Posted June 26, 2011 should very nice. Just keep em amps cool Quote YEEEEEEEEEEEEE Link to comment Share on other sites More sharing options...
Bouoy Posted June 29, 2011 Author Report Share Posted June 29, 2011 Does anyone know where I can Find the plugs for a DCX 1000x1 and the dcx 300x4 the speaker quick jacks i guess they are called. I was also thinking that I could run a line from my main A/c in the truck to help cool then down something like maybe 1/8 or 1/4 flex line. I think my only thought would be it might get a lot of moisture.Does this sound right to anyone? Quote Link to comment Share on other sites More sharing options...
Skullz Posted June 29, 2011 Report Share Posted June 29, 2011 Not a good idea really, there won't be enough foam left to make the seats comfy anymore for any type of long driving. If it is mainly for show and no go then by all means go for it but if it is a daily driver than i would rethink in putting them someplace else. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
Bouoy Posted June 29, 2011 Author Report Share Posted June 29, 2011 the only reason i thought of the seat backs was they are hollow except at the top for some reason toyota only put the foam on the front of the frame the back is sunk it with the leather draped over it. Quote Link to comment Share on other sites More sharing options...
knowledge Posted June 29, 2011 Report Share Posted June 29, 2011 deff should look good when done and done correctly, i believe you need to use a bit of glass to make it look good though Quote REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need. Link to comment Share on other sites More sharing options...
Skullz Posted June 29, 2011 Report Share Posted June 29, 2011 Let's say the seat is 4" thick and the amp is 2.5" thick you only have 1.5" to play with and with a 1/4" of plexi and then another 1/4" of plywood to mount it on your now down to 1" with no room for the amp to get any kind of airflow over it. Now if you do something where it semi sticks out while maintaining some room in the seat and allow airflow it's a viable option to try out. For install such as that i would use a d-class amp over an A/B one for possible heat issues with the A/B class and they may even be a bit thinner than a class A/B designed one. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
zayres29 Posted June 29, 2011 Report Share Posted June 29, 2011 Might want to drill holes in the plexi for fans or just to vent hot air out Quote Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged Link to comment Share on other sites More sharing options...
Bouoy Posted June 29, 2011 Author Report Share Posted June 29, 2011 thanks for the information and the Tips I would like them flush in the rear seat but hey I'll do what ever works best and looks cool second I took a picture of the back of the seats so you can see the only bulk of the foam is at the top. seats I Will do a mock up of the box and the mounting with some luma board i have left or so i can get a better view of it. Quote Link to comment Share on other sites More sharing options...
extremeauto Posted October 2, 2011 Report Share Posted October 2, 2011 i put my mids and hi's amps behind my back seats all the time never have had any issues i even USED to mount my sub amps to the rear seats in my grand am and have not had a issue yet...i do put thick rubber spacers under the amps to get the vibratoin down some and to help them keep cooler Quote 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing! Link to comment Share on other sites More sharing options...
