T115d2 Enclosure Help
Fi_all_d_way
hey guys i need some help..this is my situation
i got a fosgate T115D2 in a powerful enclosure specs box that is recommended by RF. which is 3.25cubic ft tuned 2 37hz
i wanted 2 know if any of u guy could help me out here, i want 2 get more out of the sub "MORE LOW AND LOUD" so is there any eclosure u hav in mind?..cubic ft?...port size?...port tuned to?...
i also got bass box pro 6 and when i run d specs tru the program im getting 122db @ 50hz
dont matter how hard i try the best i get is 122.5db @ 40hz but d port size is really big which is (total cubic of box with port = 9.51 :blink: Vb= 5.5 cubic tuned to 38hz. port dimension is = (H) 16 x (W) 9 x (L) 40 :blink: dat is a real big port can u guys help me plz...there is a show on d 28th of this month and i would like 2 sound bess.. :rolleyes:
iz there anyway that i can increase that 122db to may be 130db - 135db??
Well dude, what kind of vehicle is this in is? What kind of power are you running to this, any other info will help us help you! :D
Scientia est Vox
SMD SUPER BUYER/SELLER
did you get that 3.25 before or after port displacement? i built that box also...49 inches of port area at 22.5 long got great results . talked to fosgate and they said that that was dead on for their speaks for music. they dont beleive that you could go lower tuning and inprove output with the subs
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
I have 2 t2 10's with 1k on each so I put them both in a 2.5 cu ft enclosure with about 50sq " of port. but that was due to how much power I put to them. Big power is better with a smaller box and port area!
Scientia est Vox
hey pro little off topic but u said u put the specs in a program??? the program tells u how many dbs it will be?????
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
yea...it gives u alot of info...it gives u a read out of db at hz (eg. 122db at 50hz) it gives port air velocity (eg. 10 m/s at 40hz) , cone displacement at hz (eg. 5mm at 40hz) and alot more it shows it on a graph...so u can compare other enclosures an see which 1 u can get d best
performance to yuh likin...hope dis helps
  • Who's Online   1 Member, 0 Anonymous, 1434 Guests (See full list)
