06 Civic Build - New Build List on page 60
Here you can see the traced line.
The rest is pretty much basic. Pulled the foam down, and then cut the line!
So now this basically gives me a template to go off of. This gives me about an inch and a half on either side before the trunk arms and that will allow plenty of room to build my custom trim pieces on the arm itself. Remember I have an amp going up there and I have to have two 4ga power wires, a remote wire, and two sets (4 ch) of rca's going up the other side. SO I'll have to put those up the trunk arms and then build or fiberglass a trim panel to go over them.
At this point I'm going to scrap the braces and go a different route. After thinking about it, and deciding to go ahead with the actuator idea, that I'll need the bottom of the drawer exposed. So what I'll do is use this template for the top plate as well as the drawer bottom plate. So I'll take this and make a half or 3/4" plate and then have a couple of sides mounted to it for the drawer slides. Then to anchor it to the rear deck I'll use threaded inserts, and bolt down from the top. That way I can take it out if I need to without destroying the wood, although it'll be a bitch to do with that custom deck up there. But it's the best way and I'm gonna have two amps up there so there will be some weight to it, and I don't want to worry about it pulling loose. So some hurricane nuts from the bottom, and some screws or bolts with washers from the top should do the trick nicely. Then on the bottom I'll do the actuator in the center so that it can move freely and not bind. I'll then build a cover piece for the front so all you'll see is the trim piece. When it's closed you'll only see that and the sub enclosure trim piece will butt up to it. When opened, in order to see under it, you'll have to get down and look up. Not worried about that.
So there it is for now. Gonna work on building the drawer maybe this weekend. I doubt I'll have time this week. I am, however, going to try and do a couple of things that need to be finished this week. Hopefully I'll have time.
Thanks for tuning in, that's it for now.
Still waiting for someone to pick this stuff up so I can get my tablet and components! Check it out!
The way you dealt with the port/flip down panel behind the seats has really inspired me for my own build. I just hope whatever my next vehicle is has back seats that fold down the same way.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
Ok so here's the final list of things for the tablet project:
Samsung Galaxy 10.1 Tablet 32gb WiFi
Samsung Galaxy 10.1 Docking Station
Samsung Galaxy Tab 30pin Vehicle Charger
Samsung Galaxy Tab with HDMI port out
Gefen HDMI to Composite Scaler
Mini Box M2-ATX (160W) Intelligent Automotive DC-DC Car PC Power Supply
Gepco Digital Coax Cable
Firgelli 2" Mini Linear Actuator
There's the list. Lots of fabrication, due to having to relocate the HVAC controls, most likely loosing the Vent, and moving the other things. As well as making a 10.1" tablet fit in the OEM head unit location.
I'm waiting on some final wiring confirmations over at MP3Car.com but it's all pretty much a go!
Here's the updated list of audio going into this build. For the most part anyway:
Pioneer AVD-W7900 Monitors
Pioneer SE-IRM250 Headphones
Hertz Mille ML280s Signature Tweeters
Hertz Mille ML700 3" Comp Mid Range
Hertz Mille ML1600 Mid Bass
Hertz High Energy HSK-165 Rear fill (passive)
Hertz High Energy HX300D subs (12"s dvc)
Audison Bit One.1 Processor
Audison LRx 4.1k (mid range and tweeters),
Audison LRx 2.9 (mid bass),
Audison LRx 2.4 (rear fill),
Audison LRx 1.1k x 2 (subs)
Stinger - Batteries (x3 SPP1200), H/O relay, Cables (1/0 Ga, 4ga, 8ga, speaker, other wires) Front - Done March 20, 2011
Audison Connection - distribution blocks, and all connections
Mechman 220 amp alternator
Zenesis auto start alarm with window up/down modules, and sunroof modules
UPDATE UPDATE UPDATE UPDATE!!!! I'm very very exited about this! Check it out!
Straight from Best Buy, man their getting cheap. They don't even use good bags anymore!
YA Baby! Part 1 of the "Tablet Project" is here! Samsung Galaxy Tab 10.1 32gb WiFi. All they had was White but that's ok, when it's in the dash, it won't matter cause you won't see it!
This will give you an idea of the size of it. Such a little package with such a big price tag!
And there she is! Plastic film still on it! I'm not going to unwrap it now, I'm at work. I'll play with it tonight or tomorrow and get it set up etc.
Not much in the box, power cord, adapters, usb cable, booklet, and some headphones under the booklet. Like I said, small package for a big price tag!
So there you go. Part 1 is here. Next up, I'll have to get the card paid down with paypal money, and then get the rest of the parts: dock, media tab, car charger, converter, and the power supply that I end up using. I think I'm going to still use the same one, M2-ATX, but I'm also looking at a couple others as well.
That's it for now!
Ok so I got the Tablet out a little before I had to come back to work tonight. I got the charger out, wall charger that is, and started to think about it and I said "self, if this charger for the wall takes the usb cord, and the car charger takes the usb cord, then why would the voltage be any different here than there." So out came the DMM and the charger, and I took a little test. This is what I came up with!
Not sure why I needed 2 views but I took it!
So 5v for charging it is! Just thought I'd share that.
get to work lol
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
