DRauck Posted July 21, 2011 Report Posted July 21, 2011 The subs are going in a wedge behind your seats, right? Fire the subs towards the rear of the truck if you can but build ring spacers so they don't hit the back wall from excursion. They'll sound best that way. You'll probably end up needing to sound deaden the back wall however 2011 Honda CR-Z Mugen 12" Kicker SoloX Subwoofer Rockford Fosgate t20001bd Pioneer AVIC-X930BT Head Unit Build Log
BassMunky Posted July 21, 2011 Author Report Posted July 21, 2011 what the miniumum spacing i need from the wall and the subs?First time i heard of facing the subs that way lol. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted July 21, 2011 Author Report Posted July 21, 2011 something like this wedge , but with the sub on the straight part on the backside and not the slant part like in the pic right? http://www.rockfordfosgate.com/rftech/box_wizard.asp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted July 21, 2011 Author Report Posted July 21, 2011 like this right? maybe can port? what you recommend how far away from the wall? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted July 21, 2011 Author Report Posted July 21, 2011 any ideals? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
DRauck Posted July 21, 2011 Report Posted July 21, 2011 Build the biggest box you can, sealed, and make sure there's room for the spacers and it'll be good. 2011 Honda CR-Z Mugen 12" Kicker SoloX Subwoofer Rockford Fosgate t20001bd Pioneer AVIC-X930BT Head Unit Build Log
DRauck Posted July 21, 2011 Report Posted July 21, 2011 2011 Honda CR-Z Mugen 12" Kicker SoloX Subwoofer Rockford Fosgate t20001bd Pioneer AVIC-X930BT Head Unit Build Log
BassMunky Posted July 21, 2011 Author Report Posted July 21, 2011 what did you use for spacers mdf wood?Also gonna be running 2 12 chaos any ideal on how much space i need? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
DRauck Posted July 21, 2011 Report Posted July 21, 2011 We made an mdf ring that went around the sub and then cut it into 4ths. So like we took the ring and cut it in 4 pieces and used 2 on each side (one on each side of each sub like on the picture). I hope that makes sense. As for space, you'd be right on. This is with subtracted 1.5" for your trim rings which should be doubled up MDF to make it 1.5" in thickness 2011 Honda CR-Z Mugen 12" Kicker SoloX Subwoofer Rockford Fosgate t20001bd Pioneer AVIC-X930BT Head Unit Build Log
BassMunky Posted July 21, 2011 Author Report Posted July 21, 2011 will my chaos subs fit? and how does it sound facing backwards does anyone have video? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
