Hey guys im pretty sure this things toast but just want to double check. In the pics you can see how the leads made holes in the spider and one of the leads disconnected. I have a recone sitting at my house and before i go at it just wanted to clear it up, give me some feedback and let me know whats up. Thanks
225 Excessive Amperage Alt.
4 Yellow top batteries
Pioneer AVH-6600
Kicker KQ5
2 FI 18 BTL's fully loaded
2 zx 2500.1's
4 ks6.5 coaxials
4 ks5.25 coaxials
kx650.4
http://www.cardomain.com/ride/2358078
over-excursion bro. you need to make sure your subsonic filter is on and set right around 37hz plus double check your box dimensions you might have it tuned a little low if your not using a subsonic. and yes re-cone it.
I got banned for being an ignorant ass....and im a dickhole
i like men, michael jackson and large sausages
well i have it running off a zxz2500.1 and i bought this amp refurbished and ive had nothing but problems with it. I kept blowing 300 amp fuses and eventually blow this sub so i had it sent off to kicker and they fixed it all up. The other 2500 i bought was new and works perfect. I assume it was the faulty amp, what do you guys think? Also ill make sure to double check the ssf again. thanks
Pioneer AVH-6600
Kicker KQ5
2 zx 2500.1's
4 ks6.5 coaxials
4 ks5.25 coaxials
kx650.4
why would you set your ssf around 37hz when a regular crossover will go down that far? thats stupid. besides, ive heard you can get away with setting it 10hz below your tuning if yours careful. meade also said his spiders were wearing though, and mine are a little. i think its pretty common with this sub.
don't mean to be dick or nuthn but this is coming directly from Scott at FI. these BTL's do not like overexcursion at all and scott checked out the amp and re-set the ssf up that high. i'm not the rocket scientist here
so then theres absolutely no reason to build a box under 37hz tuning if you own a fully loaded 18" btl? sounds fishy to me.
Really this is because the BTL is meant to be a SPL sub or one note.
So its not really made for music, but meade and some other people have found a way to make it work.
