37hz isn't super low but its pretty low, but then again my car peaks at 45hz so anything below 40 i consider pretty low lol.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
kinda like my plans but on smaller scale
mmmmmmmmmmm that looks super sturdy. :good:
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Doh so you built 2 seperate boxes and combined them? seems like a really good idea honestly... I am still trying to figure out how im goign to build this box since it will NOT slide in after so that means I have to do what DOH did or build it INSIDE my jeep. Im really nervous about this haha. I mihgt just do the 2 boxes build screw them together and add a baffle on the back to sturdy it up sound good?
Grand Cherokee
Team Backwoods Bumpers
DC 15" Level 3's /w 4 Coils
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Audiopipe 1500.1D @ 14.4v
Clarion Equalizer
Knuconeptz Kollosus 0ga
Knuconpetz Kollosus 4ga
Coming Soon: 270xp / xs1200
Doh can you link me I cant seem to find it :-/
Grand Cherokee
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Clarion Equalizer
build 2 seperate box's the exact same and stack them bolting them to eachother and to the vehicle- dont want it falling on you
and for mine i will be welding steel frame into vehicle
R.I.P!
(Nov-29-2009)
92 explorer
current build
My wall was my first enclosure ever and I built it solo dolo. Not saying everything I did was right but it got decently loud but here's what I did.
-I did a sketchup just as you did.
-Measured tons and tons. Then redesigned sketchup accordingly.
-I then laid it out in paint and positioned pieces that I needed onto a 4x8 sheet of mdf so i wouldn't waste much wood.
-After all the wood was cut up I assembled it in my garage with no glue so I could predrill all the holes. Then attempted to take a door off my car to get it in...solo dolo (my back still hurts lol)
-Disassembled then reassembled in the car using wood glue and L clamps to hold it together
Here's a pic of tearing it out to give you an idea of what I did...this is not to be critiqued as it was my first box I've ever built and its ever changing...just tore out the foam tonight.
This was 2 18's with a center port.
My main weakness was bracing, so i can't stress enough on bracing.
Edited by BassJunkie
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Yeah I'll probably go that route... How do I go about measuring beauty panel trim for the sides? To make it fit to the side of my jeep... I dont want foam all over my shit but I want it as sealed as I can get it. Is there any type of material I can lay down on the flooor and sides so I can just satke it out after and i wont have glue and shit everywhere? I'm going to do the 2 box build and bolt them together for sure. I'm now sure how I'd go about bolting it to my vehicle and I have ZERO welding skills, I want my jeep to be usable after the least I have to tear out/cutup and ruin the better.
Grand Cherokee
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Clarion Equalizer
Use cardboard mock-ups for cutting trim panels, thats what Im in the process of doing right now.
Check under your jeep and drill from below into your box and bolt bolt bolt. (assuming theres no wires going to be under your box and under the carpet.)
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
