yes you can do that just give the surfaces a good ol' sand and youre good to go.
chevrolet all day er day.
'81 camaro z28 performance
'03 silverado ext cab show and go
I'd personally bolt it through the floor with a nut and lock washer on the outside and the bolt on the inside, sand or wire wheel the area and you're set.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Well I'm putting a bx-15 in the front of my car, about 6inches from the head unit.
Just wondering if it would be ok to ground it to the passanger seats bolt, the frame is like non existent, cuz its built-in to the floor. (1995 cutlass)....
I have no other ideas beisides the front strut mounts
If you don't mind running it to the strut mount, why not just ground at the battery and have no question as to whether or not you have a good ground?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 0 Anonymous, 2453 Guests (See full list)
