Well when you build your box, first, sealed or ported? Then, you want to build the box to get the acquired space needed, for sealed once you get a dimension your done. For ported you need to make sure that the gross volume ends up being what the manual says, which is after you take into account the port and woofer displacement. I tried to come up with a design for you, but from what I am seeing, you will need more space to be able to get the acquired 3.0 Cu after displacement, your dimensions have a Net volume of 3.64 Cuft, theres no way you can make it down to that. My boxes net volume is 4.49 Cu, and after displacements its down to 3.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Damn, I know the trunk is kind of small I just want to make sure everything is how it should be! How much bigger are we talking?
Might need around what I am have for my space, the subs I am using require the exact same space and I have a total of 4.49cu, then after everything I got it down to 3.0
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
What about a outer aero-port?
Edited by CutlassTakenDumps
That could work, I don't know anything about aero ports and how they effect tuning, can't help on that :(
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
It needs bracing, but the space he gave is workable. It would only be slightly smaller than what he needs, but that's a negligible amount.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
