i have a 1995 chevy tahoe and i was wondering if i could fit 35's under it with a 3 inch lift
with stock wheels, and some minor trimming they will fit.
center console: lvl 4 12 1.75 cu ft tuned 37htz
alpine cda-9886
dc audio 120.4
infinity kappa 6.5" components
  • 1 month later...
I dnt see it clearing when you make a turn, def. Gonna hit the fender wells. Buy a bigger lift, or cheap out and trim. Width of the tires will play a role also
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
3in suspension and 3in body should be fine. crank those keys and you can if you scrub any just trim alil. friend of mine has 33s with only torison bars cranked. im fixing to take the body lift out of mine just go with one inch body and put it on 33s. 35s to expensive for me
2001 Dodge Ram Quad Cab.
  • 2 months later...
I would so no, I had a silverado with a 6" lift 20x12 and 35s and I still had to cut about 3" off my front bumper and some off the fender well lining. Also depends on what type of offset wheel you'll run. Hope this helps
  • 3 weeks later...
No you cannot, it is to wide, you can crank your bars about an inch and add a key, and a 3 inch block for a 3 inch suspension, that would clear 33 12.50s on an 8 inch wide rim, even adding a 3 inch body on top of that, it still requires trimming or with a 305 size tire.. bout a 34-34.5 x 12 no trimming
Laying frame soon.. System has to wait
