GroundPounderz Posted June 30, 2011 Report Share Posted June 30, 2011 i have a 1995 chevy tahoe and i was wondering if i could fit 35's under it with a 3 inch lift Quote Link to comment Share on other sites More sharing options...
badasschevy Posted July 2, 2011 Report Share Posted July 2, 2011 i have a 1995 chevy tahoe and i was wondering if i could fit 35's under it with a 3 inch lift with stock wheels, and some minor trimming they will fit. Quote center console: lvl 4 12 1.75 cu ft tuned 37htz alpine cda-9886 dc audio 120.4 infinity kappa 6.5" components Link to comment Share on other sites More sharing options...
Mert Posted August 15, 2011 Report Share Posted August 15, 2011 i can almost clear 35s with just a 3" bl. if you crank the torsions you should be fine with a 3" Quote Link to comment Share on other sites More sharing options...
lifted_silverado Posted August 15, 2011 Report Share Posted August 15, 2011 I dnt see it clearing when you make a turn, def. Gonna hit the fender wells. Buy a bigger lift, or cheap out and trim. Width of the tires will play a role also Quote Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins Link to comment Share on other sites More sharing options...
bassaholicsfl Posted August 15, 2011 Report Share Posted August 15, 2011 3in suspension and 3in body should be fine. crank those keys and you can if you scrub any just trim alil. friend of mine has 33s with only torison bars cranked. im fixing to take the body lift out of mine just go with one inch body and put it on 33s. 35s to expensive for me Quote 2001 Dodge Ram Quad Cab. Link to comment Share on other sites More sharing options...
vicjac1 Posted October 27, 2011 Report Share Posted October 27, 2011 I would so no, I had a silverado with a 6" lift 20x12 and 35s and I still had to cut about 3" off my front bumper and some off the fender well lining. Also depends on what type of offset wheel you'll run. Hope this helps Quote Link to comment Share on other sites More sharing options...
99fullsizechevy Posted November 15, 2011 Report Share Posted November 15, 2011 No you cannot, it is to wide, you can crank your bars about an inch and add a key, and a 3 inch block for a 3 inch suspension, that would clear 33 12.50s on an 8 inch wide rim, even adding a 3 inch body on top of that, it still requires trimming or with a 305 size tire.. bout a 34-34.5 x 12 no trimming Quote Laying frame soon.. System has to wait Link to comment Share on other sites More sharing options...
