Lets Start with the Soundstream EQ
50.00 shipped or picked up.
BRAND NEW IN BOX
Specs:
Isolated PWM power supply
7 bands parameter equalizer with 18db boost Cut
Volume control with up to 8 volts RMS of output
Specific bandwidth for each band
Low noise BI-FET op-amp design yields minimum distortion
Subwoofer outputs and level controls
Subwoofer frequency selection switch (32Hz! 64Hz! 128Hz)
Input selector for Aux or CD
Universal half-D IN chassis for ease of installation
Gold-plated RCA input output connectors
20dB headroom eliminates signal overload
S/N Ratio 110dB @1V
Maximum output voltage 8V
THD:0.01%
Pics:
Its a good alternative to a 200.00 AudioControl EQ.
Thanks for looking.
***Now onto the AUDIO CONTROL OVERDRIVE line driver. I used it for a few months but I removed my system and have no reason to keep it. what you see in the pics is what it comes with. I can throw in a short RCA to run from the amp to the line driver if you want. The wire that you see is Rockford Fosgate and so is the RCA I have.
Details:
line driver provides up to 24 dB of gain (9 volt RMS maximum)
white steel chassis with gold-plated RCA jacks
top-mounted controls for easy adjustment
2-channel preamp inputs and outputs
balanced inputs and outputs eliminate noise
light indicates 2-, 5-, or 7.5 volt output
frequency response: 10 to 100,000 Hz
signal-to-noise ratio: 110 dB at full output
maximum output level: 9.5 volts RMS (13 volts peak)
fuse rating: 1 amp
size: 5"H x 4-1/4"W x 1-1/4"D
weight: 2 pounds
Pics:
60 SHIPPED
IF YOU BUY BOTH I'LL DO 100 SHIPPED
:drinks:
Edited by focalrock4life
yup fix it now.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Do the soundstream knobs light up?
Edited by someone1
Danget, nevermind it doesnt have what I wanted :/ my bad
Edited by someone1
This topic is now closed to further replies.
