i have 2 PB 12s model S-124d dvc 4ohms max=600 rms=300 in a slot ported box. My amp is SSL EV2.1000Tri-mode operation
Bridgeable
2 Ohm Stereo Stable
Variable low pass crossover: 40-150Hz
Fixed high pass Crossover (200Hz)
Variable 0 to +18dB Bass Boost
Frequency response: 9Hz - 50kHz (+/- 3dB)
Max power 2 ohm 500W X 2
RMS power 4 ohm 200W X 2
Bridged power 4 ohm 1000W X 1
Signal-to-noise ratio 105dB
THD at RMS output 0.01%
Damping factor 125+
i wired the sub parallel series and bridged at amp. i, worried i might blow subs because amp bridged at 4 ohm is 1000w rms so what do i do
Re Edit. I have my level at 25%, low pass halfway and bass boost at 18 db on amp. 0 db on remote and sub +10 db on headunit
Turn Bass Boost off, set gains with an oscilloscope or DD-1, that amp isn't putting out 1000wrms, more like 400wrms bridged at 4ohm. Your subs are rated for 300wrms, you will be fine.
Thank you i just bought the system and installed myself just didnt want to blow it already
Like he said, turn bass boost off, set bass to 0 on head unit. If it's not as loud as you want, get someone to set it with an oscope, you might be able to turn the gain up a bit depending on your headunit.
:rofl:
:wub: N8.
No homo...unless you want there to be. :orly3::ehh:
Yeah man, never worry about the max rating on amps, that number really doenst mean anything... The RMS is what matters and is actually more like the "max" output of your amp
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
  • Who's Online   0 Members, 0 Anonymous, 3029 Guests (See full list)
