xXsquintyeyesXx Posted July 3, 2011 Report Posted July 3, 2011 -How much power do you have to be running before you should get a new alt. -What alt would be the best to get? -Would it be bad for my electrical system to have a larger alt in my car before I get the larger amps?
mbdblue Posted July 3, 2011 Report Posted July 3, 2011 -depends on the kind of car and what alt comes stock.. -DC Power, Excessive Amperage, Mechman, Ohio Gen to name a few -shouldn't be as long as its for a 12 volt system AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
tonedeaf Posted July 3, 2011 Report Posted July 3, 2011 More batteries > alt first. I'd say after atleast a second battery, with the one under the hood is a better jump then a straight with say stock battery. If you have say 2 or 3 high quality AGM batteries such as kinetic 2400s or xs power, etc. you should be upgrading alt around then. You can't run around 2000 watts rms on stock electrical without a stupid amount of drop. Once you're pushing 3-4k an alt is probably needed. Brands are like blue said, I personally like DC Power alts. And an aftermarket alt won't hurt your car as long as it's made for it and hooked up right. Make sure you have the big 3 done or are going to when the alt gets put in.
skittlesRgood Posted July 3, 2011 Report Posted July 3, 2011 you could spend $500-700 in batteries and have voltage drop to 12.Xv plus all that weight and wiring or you can spend around $500 for an alt and stay closer to 14v. an alt wont hurt your car. it only makes as much power as you need. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
