Anyone else see te terrible grounding location on the sheetmetal attached to the rear deck?
Also, how hard is porting through the rear speaker holes in the rear deck? Should help your score alot. As for the pics, doesn't look like a lot got done. :shrug:
:good:
SuperBass
check out⊂ http://www.youtube.com/Bassknots
129.3 meca 136.8 db drag (60 hz peak)
http://bassknotsstereo.blogspot.com/
comment/subscribe and stay tuned ,working on 150 db http://www.stevemead...r/page__st__380
:good:
yeah man change the ground while everything is still out, just to avoid future problems. solder some ring terminals on them too because that shit will always be falling out and stuff
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
sloppy grounds, put some ring terminals on those ends.
1996 mustang gt
  • cobra bumper
  • cowl hood
  • c-spring lowered
  • msd ignition, frpp wires , ngks
  • 2 chamber flowbasterds
Sound system
  • Pioneer headunit
  • clarion eqs746
  • polk audio mm571's 5x7's
  • polk audio mm691 6x9's
  • planet auido bb150.4 for highs mids
  • stock mach 460 mids and walmart silk dome tweets
  • planet audio bb2400.1
  • 2x 1242 d4 alpine type r's
  • 3.5 cu enclosure tuned to 32 hz
  • all knu concepts & tsunami 1/0 ofc amp runs and monster powerflex big three ofc runs.
  • 2xkinetik khc600 batts in parallel.
Yah you can lose 1db just for one bad connection.....fix that ish lol....
and i think your build is just confusing me? whats all that blue shit laying around on the floor and stuff?
and put some ring terminals on your grounds man, and grind the paint off of that shit, you need a good connection. i guess i dont see why you took literally EVERYTHING out of the car to do that install man lol
x2 - i was thinking the same thing. and i'd start with the fundamentals before trying to reach 150. i hope you do it though...
The only thing wrong with that ground is that its ugly.can you guys calm down Ring terminals will be installed soon enough you'll see .sometime there is more there then meets the eye.it is a temp ground but im not changing it yet(
SuperBass
Lol well that's not the only thing wrong with it, it's on a painted surface for one, and on a flemsy piece of sheet metal. You should try to find a bolt that goes directly to your frame, or drill you a little hole and run the cable through it and bolt it directly to the frame. A nice seat mount could work, just make sure you grind the paint off.
I'm not tryin to hate, I'm just trying to help :)
so far...
Where you have that ground is a very bad place lOL! I can bend that metal with my hand. I had a lumina, that deck is held in with spot welds and adhesive. I would either ground it to the strut tower or the seat belt buckle bolt will do if you grind the paint around from the area.
I'm not hating, I'm just saying.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
That thing is on bear metal y'all don't see all the paint missing...lol y'all trying to be funny..the ground is fine
& i said its a darn good ground and this particular place is not held together by silicone .its connected to the frame metal to metal
SuperBass
At least y'all tried fellas...
