Rich859 Posted July 6, 2011 Report Posted July 6, 2011 Ok, so I have a 2004 Dodge ram 1500 SLT Quad cab. I am planning on getting 2 DC audio lvl 3 subs and putting them in a box under my back seats. I need to know what amp I should use. I've been told AQ 1200, but I looked around and saw some cheaper, higher watt amps. Are there any true watt amps for cheaper than the AQ? Or is there a better amp I should be using? I need opinions please.
ChevyBoy95 Posted July 6, 2011 Report Posted July 6, 2011 Ok, so I have a 2004 Dodge ram 1500 SLT Quad cab. I am planning on getting 2 DC audio lvl 3 subs and putting them in a box under my back seats. I need to know what amp I should use. I've been told AQ 1200, but I looked around and saw some cheaper, higher watt amps. Are there any true watt amps for cheaper than the AQ? Or is there a better amp I should be using? I need opinions please. that isnt a good combo when it comes to car audio. AQ makes a solid amp. Go with the 1200D, you wont be let down. (i have 2 aq1200ds) Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Watch the bass Posted July 6, 2011 Report Posted July 6, 2011 My link , that is cheaper than an AQ, do rated, is well known as budget brand and you get a fuseholder with fuse, with it. The AQ´s have a better dampingfactor and the AQ bassknob have a clippingcontrol. "in the abundance of water, the fool is thirsty" Bob Marley
Rich859 Posted July 6, 2011 Author Report Posted July 6, 2011 I was thinking the AQ would be best, just double checking because I'm not too familar with how good any amps except JL are, and those are expsensive. Looks like I'll go with the AQ 1200d on the 2 dcs. Thanks for your inputs.
ChevyBoy95 Posted July 6, 2011 Report Posted July 6, 2011 My link , that is cheaper than an AQ, do rated, is well known as budget brand and you get a fuseholder with fuse, with it. The AQ´s have a better dampingfactor and the AQ bassknob have a clippingcontrol. its funny, i knew what amp before i even clicked. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
