RiddleRampage84 Posted October 17, 2007 Report Posted October 17, 2007 If I make the port bigger than the minumim port area required, will I get port noise, any help would be great, I wanna build the box sometime this weekend!! 2000 Chevy Blazer ALT. - Mechman 270amp DECK - Pioneer DEH-P4000UB INTERIOR - Infinity Reference 6020cs INT. AMP - RF P400-4 SUBS - 2 15" RF Punch P3s SUB AMP - RF T1000-1bd REAR BATT. - Stinger SPP1200 Just a lil sum sum to get me back in the game!!
Dale Posted October 17, 2007 Report Posted October 17, 2007 If you have a program like winISD, it can tell you the velocity of the air leaving the port...you can then determine whether or not you should increase/port area. Tell me the sub you plan to use, the size of your enclosure and I should be able to tell you the minimal port area without having port noise
RiddleRampage84 Posted October 18, 2007 Author Report Posted October 18, 2007 If you have a program like winISD, it can tell you the velocity of the air leaving the port...you can then determine whether or not you should increase/port area.Tell me the sub you plan to use, the size of your enclosure and I should be able to tell you the minimal port area without having port noise I have 2 15 Audiobahn Flame Qs, a Hifonics BXi1606 at 1 ohm, I want my box to be 15Hx38Wx30L(8cu. ft.) I would like it to be tuned to 32hz, subs up port back, using a square port, just like steve's box for his 18s but of cousre smaller Thanx man 2000 Chevy Blazer ALT. - Mechman 270amp DECK - Pioneer DEH-P4000UB INTERIOR - Infinity Reference 6020cs INT. AMP - RF P400-4 SUBS - 2 15" RF Punch P3s SUB AMP - RF T1000-1bd REAR BATT. - Stinger SPP1200 Just a lil sum sum to get me back in the game!!
andym85 Posted October 18, 2007 Report Posted October 18, 2007 assuming those are external dimensions, and that u use 3/4"wood, and assuming each sub displaces .2cubes (<---just a guess) then a port 12"x6" that is 22" long will put u around 32hz (probably gonna have to do a 'L' shaped port...that will leave ur box at about 6.4cubes net (after sub/port displacement) edit: sorry, i just noticed u were wondering about minimum port area... reading>me...but i will leave my post anyways i likes me some audio stuff...
RiddleRampage84 Posted October 18, 2007 Author Report Posted October 18, 2007 assuming those are external dimensions, and that u use 3/4"wood, and assuming each sub displaces .2cubes (<---just a guess)then a port 12"x6" that is 22" long will put u around 32hz (probably gonna have to do a 'L' shaped port...that will leave ur box at about 6.4cubes net (after sub/port displacement) edit: sorry, i just noticed u were wondering about minimum port area... reading>me...but i will leave my post anyways thanx, yea I have the port size figured, my ? was I got the figure for the least amount of port area I can have, If I make the port bigger than that Im ok right? 2000 Chevy Blazer ALT. - Mechman 270amp DECK - Pioneer DEH-P4000UB INTERIOR - Infinity Reference 6020cs INT. AMP - RF P400-4 SUBS - 2 15" RF Punch P3s SUB AMP - RF T1000-1bd REAR BATT. - Stinger SPP1200 Just a lil sum sum to get me back in the game!!
RiddleRampage84 Posted October 18, 2007 Author Report Posted October 18, 2007 Is there anyone out there that can answer my ? pleaze, help needed 2000 Chevy Blazer ALT. - Mechman 270amp DECK - Pioneer DEH-P4000UB INTERIOR - Infinity Reference 6020cs INT. AMP - RF P400-4 SUBS - 2 15" RF Punch P3s SUB AMP - RF T1000-1bd REAR BATT. - Stinger SPP1200 Just a lil sum sum to get me back in the game!!
Sinosic Posted October 20, 2007 Report Posted October 20, 2007 If I make the port bigger than the minumim port area required, will I get port noise, any help would be great, I wanna build the box sometime this weekend!! no you wont get port noise cause you made the port bigger. lets say your current port is 2" wide by 14" tall and 30" long which would tune the box lets say 35hz if you made the port wider say to 5" and left the hieght and lenght the same the box will have less port noise but will be tuned alot high. a port with alot of port area has to be longer to be tuned at any given hz than a port with less port area. be careful cause you dont want to much port area. i hope this helps [email protected]
Sinosic Posted October 20, 2007 Report Posted October 20, 2007 also if you have the min port area it is ok to go bigger. just know by doing a larger port the internal volume of the box will change, tuning will change. i would use the enclosure software at re audio website [email protected]
