:shrug:
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
If you need to ask that, you should probably work on your electrical first.
¿ǝɯɐƃ ǝɥʇ
Is the box going to be double baffled and single layer on the other pieces, double layered all around, etc. Or is that part of the question.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
A shitload... :peepwall:
Depends what wood your using. Double up each side if using mdf, get some allthread that goes top to bottom, depth wise, and width wise if you can.
If using birch, just double baffle and then do as I said for the rest of mdf
And I'd lay a little bit of glass inside too, atleast a few layers in all corners. Too much bracing never hurts, if ou have the space :)
Edited by Louisiana Bass
:rofl:
:wub: N8.
No homo...unless you want there to be. :orly3::ehh:
if you dont know how to brace a box to handle how ever much power you plan on using than you need to start back over at the beginning at like 1k
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
well i knew double baffle but what about the inside?
Will the subs be mounted vertically or horizontally, how heavy are the subs, what subs are you using, single or double baffle?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
