I Was Thinking...
Here is what I was thinking about doing...
Getting two more assassins, wiring the 4 of them to one Ohm.
Then buying a Crunch PZI 3000.1D
PZI 3000.1D
D-Class Mono Amplifier
3000W 1-Channel
750W x 1-Ch @ 4-Ohms or
1500W x 1-Ch @ 2-Ohms or
3000W x 1-Ch @ 1-Ohm
I'm sure it's good for at least 2000W RMS at 14.4V thus still being able to give each of my assassins 500W RMS. and for $220 that's not bad
I'm gonna upgrade my power from one run of 4 gauge to a 4 gauge run plus a 0 gauge run.....
about 3CF tuned to 30Hz sound alright? or should I tune higher with the 8's?
225HP 1996 S-Dime
JVC KD-G820
Crunch PZi 2250 powering Two Ascendant Audio Assassin 8s wired to 2 ohm at 225W RMS 2.26CF @ 36.4Hz 43.5 square inches of port with 45's
Kicker ZX350.4 powering CDT CL-61A's with TW-24 Tweeters
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
MSN: [email protected]
i actually just picked up an issue of 'Performance Auto and Sound" today...and they benched it at 14.4V and it did 3,343watts x 1 at 1 ohm...and at 12.6V it did 2,628watts...just though id let u know
i likes me some audio stuff...
there is 2 of those 3k watt amps though by crunch. idk if its the same........
one I know isn't overrated, its the GP line so it was probably that one....
anyone else?
225HP 1996 S-Dime
JVC KD-G820
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
ahh...i dont think it is the same amp...the one i read about was the GP3000D...sorry..
Amplifier Specifications:
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 750 watts x 1 channel
RMS Power (2 ohms) 1500 watts x 1 channel
RMS Power (1 ohm) Not Specified
Bridged RMS Power Not Bridgeable
Peak Power Output 3000 watts x 1 channel
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power .10%
Speaker Level Inputs No
Preamp Outputs Yes - 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 35 - 250 Hz
Subsonic Filter 15 - 35 Hz
Signal-to-Noise Ratio 93 dB
Channel Separation N/A
Bass Boost 0 - 10 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 50A x 2
You will not see more than 1000-1500watts rms out of that amp.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
but the BXi 1606D has two 35A fuses and it does just about rated power, how could the amp with two 50A fuses do less?
225HP 1996 S-Dime
JVC KD-G820
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
so something with much lower amprage fuses will do almost the same as the one with 100???
225HP 1996 S-Dime
JVC KD-G820
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
  • 3 weeks later...
