That1Kid Posted July 9, 2011 Report Posted July 9, 2011 This is my first time hooking up a head unit. Trying to put in a 98 Expedition. I connected the constant 12v, switched 12v, and ground wire. I pressed the reset button like the manual says, but the unit will not power on. What could be the problem? Do all the other wires need to be connected first? I have a feeling I already screwed it up beyond repair. Thanks guys -98' Ford Expedition (Rest in Peace) -AVH-P3300BT -Crescendo BC5500 -4 18" DC m2 Level 3.
jshark5 Posted July 9, 2011 Report Posted July 9, 2011 Check the fuse on the radio and try running your own power and ground to it. I had an issue one time where the power wire didn't work so I had to run my own. I have no idea why it quit working though. You could also make a new ground too. 04' Chevy Blazer -Kenwood KIV-BT900, Infinity Kappa 462.9cfp's, Rockford P1653's, Subs... Ridin Stock-
That1Kid Posted July 9, 2011 Author Report Posted July 9, 2011 Tried it with the car running...and with the key turned with the car not running. Edit* jshark, i had the stock radio playing today. Fuse on the unit seemed fine. I wonder what would cause the power/ground to quit? I'll definitely try it though. Thanks man -98' Ford Expedition (Rest in Peace) -AVH-P3300BT -Crescendo BC5500 -4 18" DC m2 Level 3.
Bumpindemlowzz Posted July 9, 2011 Report Posted July 9, 2011 Run a different 12v constant and switched wire from fuse panel and see if it works. Some harnesses they dont work for some reason. 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
That1Kid Posted July 9, 2011 Author Report Posted July 9, 2011 Gonna try that when I get off work. Thanks -98' Ford Expedition (Rest in Peace) -AVH-P3300BT -Crescendo BC5500 -4 18" DC m2 Level 3.
That1Kid Posted July 12, 2011 Author Report Posted July 12, 2011 Lol still workin on this...damn I have power at the 12 volt switch wire only now. I'm on the verge of hangin it up at this point. -98' Ford Expedition (Rest in Peace) -AVH-P3300BT -Crescendo BC5500 -4 18" DC m2 Level 3.
