Getting my WHOLE electrical planned
I wont have the system I want for a while. But I want to make sure I know everything I will need, and how to get it all ready before I get it. In the end I will have a RF T1500.1bdCP running on 2 DC Lvl 3 12's and either a T400.4 or a T600.4 running Punch or Power 6x9's in the rear, and a Punch or Power 6.5 component set up front. I will be doing the Big 3 in 1/0 wire, which is going to around 30 ft, give or take some. I will be doing 2 runs of 1/0 to the back, I will be doing - terminal to the ground. SO I will most likely need around 75ft of 1/0 running on around 2000 watts. I looked up the chart, so I will have a 350A fuse on the power wire from the battery. Both runs to the back will hit a distributor, for the 2 amps, I need to fuse both the power wires off the distributor correct? If so what A fuse should I use off that? I have a 60A stock alternator, I know this will not be good enough for running what I will have. This set up also will be the highest I will ever have in this car, so what would be a good Amp alternator size to look for to replace mine. I will use 8awg wire for my subs, and 14awg for the rest of my speakers. Would anyone suggest running a second battery in the back? Or if I just get a nice battery upfront would that be able to handle a 2k watt system with normal car accessories fine?
List:
75ft 1/0 wire
25ft 8 awg wire
100ft+ 14 awg wire
2x 1/0 distribution blocks
300A fuse and holder for power wire
???A fuses for distribution block to amp?
Alternaotr and batteries???
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
bump
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I have an XS d3400 in the back of my car. I run a DC 2K, DC 175.4, and a Hifionics 100.4. I would suggest getting a battery for the back. Two battery's are better than one if you get the proper battery. Or, if you get a aftermarket alternator with good output, a good battery up front would be ok I think. Someone correct me if I'm wrong.
2012 Nissan Altima SL
DC M2 Lvl 3 12" with AR cone
DC 1.2K Amp
Kicker Sum8
Kicker 4 Gauge amp kit
XS Power D2700
1.5 Cubic ft net tuned to 38Hz
Thats what I was thinking fo just doing, just getting a good alt with a good battery upfront.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
List:
350A fuse and holder for power wire
300a. Unless you have some special 1/0.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Depending on your system I would run 2 decent batteries. From the sounds of things you have enough wire to run 10k watts lol. I have 3 runs 1/0 to my rear battery and 2 batteries under my hood with a 200amp alt on roughly 3500rms and at .5 and around 4k I dont drop below 12volts
Since were all having a moment of truth.
I hate country too..
I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick.
K will chance to a 300A fuse, thinking of something around a 200A alternator, with a nice battery upfront so I wont have to have a battery int he back, because I really wont have enough room.
Edit: FYI the 75ft of 1/0, is 2 runs to the back, and rest is for the Big 3.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 1231 Guests (See full list)
