Well, not really looking for the best, but just looking for some opinions of some good 2/10/20 (or close) chargers. I'm looking to grab a pair of matching ones in the upcoming months, and just want to see what you guys have had good results with. I personally have used Vector chargers, which are the same ones that Kinetik used to use for their 12V charger. I have a 2/6/10 and a 2/10/20 as of right now...might grab another 2/10/20 if I can, or maybe step it up to the 2/10/20/35-40.
Edited by RAM_Designs
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
I slow charge.
I use ctek
Worth checking out at least.
Very neat
I slow charge.
I use ctek
Very neat
Thanks Ray, I'll look into it. What model do you use? I'll need something that can handle charging a string of 10 100lb batts.
Uhh. The 150.00 one on amazon??? Lol
Mine only does 2 at a time really.
Id buy a cascade 100amp power supply if i were you
R.I.P!
(Nov-29-2009)
92 explorer
current build
So were those 10batteries i bet.
Gotta pay to play
You know that
Aps75
Pull the trigger man
You can find them for just over 200
I figure just buy the last charger you need ever
Instead of fuggin around with cheaper ones
CTEK is truly great stuff!
Check out their largest; US2500. http://smartercharger.com/products/batterychargers/ctek-multi-us-25000/
Anyone with more than 2-3 batteries should get one of these to regularly get some extra juice put in. Just plug in and let it be. HAndles up to 500Ah battery banks.
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
  • Who's Online   1 Member, 0 Anonymous, 1755 Guests (See full list)
