Posted (edited)
Well, not really looking for the best, but just looking for some opinions of some good 2/10/20 (or close) chargers. I'm looking to grab a pair of matching ones in the upcoming months, and just want to see what you guys have had good results with. I personally have used Vector chargers, which are the same ones that Kinetik used to use for their 12V charger. I have a 2/6/10 and a 2/10/20 as of right now...might grab another 2/10/20 if I can, or maybe step it up to the 2/10/20/35-40.
Edited by RAM_Designs
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
I slow charge.
I use ctek
Worth checking out at least.
Very neat
Posted (edited)
I slow charge.
I use ctek
Very neat
Thanks Ray, I'll look into it. What model do you use? I'll need something that can handle charging a string of 10 100lb batts.
Uhh. The 150.00 one on amazon??? Lol
Mine only does 2 at a time really.
Id buy a cascade 100amp power supply if i were you
R.I.P!
(Nov-29-2009)
92 explorer
current build
So were those 10batteries i bet.
Gotta pay to play
You know that
Aps75
Pull the trigger man
You can find them for just over 200
I figure just buy the last charger you need ever
Instead of fuggin around with cheaper ones
  • Who's Online   1 Member, 0 Anonymous, 655 Guests (See full list)
