If you added a new battery in the back the battery under the hood would drain the new battery voltage. unless you have an battery isolator
ive done it quite a few times with out a isolator and never had a prob some were a yr or so and some were a few months
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
Gotcha, So if I got a Shuriken battery for the trunk and kept the one up front would it cause any problems?
If you let the car sit for an extended period of time the batteries would end up draining each other. It fight this it is recommended to use an industrial relay (200+ amps) or a battery isolator. This is only if the vehicle will sit for an extended period (a month or more). If you are using this vehicle on a daily basis everything should be fine.
