RFpunch Posted July 15, 2011 Report Posted July 15, 2011 i have a rf hx2 12inch and seen people running alot more power than whats recommended, is this safe since rf likes to underrate there stuff
zx10intn Posted July 15, 2011 Report Posted July 15, 2011 to a certain extent, it is as long as the power is clean and not clipped. many subs are in that same category, they can take a bit over rated rms as long as its clean, the problem is, a lot of people out there try to give a clipped 500w to a 400w sub and thats when the problems start 1969 Chevy Chevelle 20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's Mechman 250amp cs144 alt w/AVBM Kinetik 1800 main battery/Kinetik 2400 in the trunk Pioneer AVH-3200dvd Headunit (2) sets of Hybrid Audio Technologies Imagine components up front (2) DD 3512's d4 coils Sundown sax100.4 component amp Sundown saz-3000d subwoofer amp 5ft^3 box tuned to 34hz MY BUILD
ISO Posted July 15, 2011 Report Posted July 15, 2011 I'm usually always comfortable running an amp that is 200 watts over the rating on a subwoofer. I run a BD1500 between 2 HX2's (800 watts apiece) and I think they could take a little more power. I would not go over 1000 watts and 1000 might be pushing it. Over 1000 and I can hear the Voice Coil slam the back plate to much. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
RFpunch Posted July 15, 2011 Author Report Posted July 15, 2011 I'm usually always comfortable running an amp that is 200 watts over the rating on a subwoofer. I run a BD1500 between 2 HX2's (800 watts apiece) and I think they could take a little more power. I would not go over 1000 watts and 1000 might be pushing it. Over 1000 and I can hear the Voice Coil slam the back plate to much. yea i see alot of people run 800 watts on these, so im going to eventually get a new amp to give more power
RFpunch Posted July 15, 2011 Author Report Posted July 15, 2011 to a certain extent, it is as long as the power is clean and not clipped. many subs are in that same category, they can take a bit over rated rms as long as its clean, the problem is, a lot of people out there try to give a clipped 500w to a 400w sub and thats when the problems start thanks for the info.
kirill007 Posted July 15, 2011 Report Posted July 15, 2011 If you are only going to overpower them by 100-200watts, then there is no need to do it. You can't hear that difference. Thinking is the root of all problems... You ALWAYS get what you pay for.
RFpunch Posted July 17, 2011 Author Report Posted July 17, 2011 If you are only going to overpower them by 100-200watts, then there is no need to do it. You can't hear that difference. ik that but was having trouble looking for amp.
