thats the plan and yes i was so shocked when i came home to the huge ass box i just couldnt visualize how big it really would be until i saw it in real life.
alright guys its in and playing! now in my wiring kit i got about 3-4 ft extra of power wire more than i need i just wanted to hook up and go since it was dark but im thinking i may be losing current/power due to the power wire being longer than necessary. the sub seems to hit hard and get low but i really think its hungry for more power i played it pretty good for bout an hour and a half straight and neither sub nor amp got even remotely warm on an 80 degree day. i set gains with decafs 50 hz 0db test tone and backed off when i saw clipping on the knob. was this an accurate way to do it? just seems like i could get more out of this setup i mean its loud but i hear no distortion even if the clip light lights up.
  • 1 month later...
alright guys back from the dead. been about a month now and ive deadened everything. broke a few things inside and had to fix them now im starting to think my port may be too small for this sub. ive designed a new box with the torres calc. its 8.41 cu ft tuned to 38 hz and 16.35 inches of port area per cube. heres how it should look. does this seem like it would be louder?
that box is fine for the sub, 6.5-7 cubes net Max, even 7 cubes is a lil big IMO.
if you want louder, id throw more power at that sub, slap a AQ2200D on it :drinks:
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
the box i have now or the new design and plans are to throw a 2200 on there after i get my electrical proper:)
i would keep the box you have now, the new design is too big IMO.
that HDC3 will love the AQ2200D. espically since you have the new design with the new suspension it looks like.
If your going to get that 2200 i would make the box around 5.5-6.5 cubes after all displacements tuned around 34hz
Edited by Bumpindemlowzz
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
problem with the old design is im at like 13 inches of port per cube.. i hear the aq like around 15-16. i could make a smaller version of the new box fairly easy i just see a lot of boxes with the port on bottom and in the middle rather than on drivers side like mine.
i did get the new basket i wasnt aware they changed anything else is this sub more power hungry? because honestly i feel as if its just laughing at the aq1200 i have played it for an hour solid just slammin it in 95 degree weather and it doesnt even get warm.
Even aq says that the hdcs can handle a 2200, and alums 2-3k. That was what i was told when I emailed them about power handling. A 1200 is fine, will get better as it loosens up, but a 2200 is needed to reach it's full potential I would imagine.
