dkahns51 Posted July 17, 2011 Report Share Posted July 17, 2011 Ok, so there is the video cable that goes to the deck, got that in. Then another cable that comes from the camera with red/black wires. I grounded the black on the chasis near the back.. For the red wire i hooked it up to the remote wire going to the back amps. Its not working... So do i need to bring the red wire all the way up front and hook it to the Yellow 12v constant from the harness? or what should i do with it? Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time Link to comment Share on other sites More sharing options...
Louisiana Bass Posted July 17, 2011 Report Share Posted July 17, 2011 (edited) Im probably a dumbass Edited July 17, 2011 by Louisiana Bass Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
dkahns51 Posted July 17, 2011 Author Report Share Posted July 17, 2011 Maybe you can put it in the positive terminal of the amp to see if it works? Amps are not hooked up right now, so no i cant . But that doesnt sound right... Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time Link to comment Share on other sites More sharing options...
BlitZ Posted July 17, 2011 Report Share Posted July 17, 2011 wire the red to your reverse lights. that way it comes on when you shift into reverse. Quote old set up Alpine IDA-X305S Memphis M-Class 4x6" Focal Access 6.5" Hifonics BRZ2100.1D 2x DC Audio Lvl 4 15's Big 3, DR44 Alt, Yellow Top http://www.youtube.com/user/SicNoma003 Link to comment Share on other sites More sharing options...
Quiet Posted July 17, 2011 Report Share Posted July 17, 2011 (edited) The cam probably takes 250mA to half an amp of current, especially if it's got IR LEDs. It's probably more than your deck can put out on the remote wire. Use a relay to make sure it gets the current it needs My link hope this helps. Dont' worry about the fuse calculator stuff, I just posted it for the wiring diagram EDIT: premature ePOSTulation Edited July 17, 2011 by srp365 Quote 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
dkahns51 Posted July 17, 2011 Author Report Share Posted July 17, 2011 wire the red to your reverse lights. that way it comes on when you shift into reverse. I have the Reverse signal wire from deck going into the reverse wire for car. The cam probably takes 250mA to half an amp of current, especially if it's got IR LEDs. It's probably more than your deck can put out on the remote wire. Use a relay to make sure it gets the current it needsMy link hope this helps. EDIT: premature ePOSTulation Broken link. Maybe i should just run it to the back battery? Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time Link to comment Share on other sites More sharing options...
BlitZ Posted July 17, 2011 Report Share Posted July 17, 2011 wire the red to your reverse lights. that way it comes on when you shift into reverse. I have the Reverse signal wire from deck going into the reverse wire for car. you could wire it to that. or just tap into the light if you dont want to run the wire all the way up. Quote old set up Alpine IDA-X305S Memphis M-Class 4x6" Focal Access 6.5" Hifonics BRZ2100.1D 2x DC Audio Lvl 4 15's Big 3, DR44 Alt, Yellow Top http://www.youtube.com/user/SicNoma003 Link to comment Share on other sites More sharing options...
STR8BLaZiN Posted July 17, 2011 Report Share Posted July 17, 2011 I have mine wired to reverse lights like BlitZ said.. turns on automatically on reverse and its been working for about a year now no problems.. Quote Team Bass Hz - Louder. Lower. - Team SoCal SPL 2010 West Coast Regional 130-139.9 Bass Race CHAMP Link to comment Share on other sites More sharing options...
dkahns51 Posted July 17, 2011 Author Report Share Posted July 17, 2011 I Wired it to the battery.. and then grounded it to chassis. I got the yellow video going up to the deck and nothing is happening at all. It doesnt turn on, and on the Head unit it shows it greyed out like its not connected. Any thoughts? Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time Link to comment Share on other sites More sharing options...
kickass audio Posted July 17, 2011 Report Share Posted July 17, 2011 just so u all know, i helped him figure it out. It was wired up right but the feature was never turned on correctly, it was set to off on the wire, not +12v like it was supposed to be so now its working for him. Quote 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress Link to comment Share on other sites More sharing options...
