i was wondering how i would calculate port when doing a kerf.
like using torres, how would i enter it into the program?
thanks
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
some say 1/3 of the kerf length is actual port length. it depends on how large the kerf is. if its an inch then it is basically noneffective. another rule of thumb is 1/2 the length. i haven't found any published literature confirming any calculations. for box building purposes i add 1/2 of the kerf length to the port length and the tuning should be close to the calculated tuning in torres.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
half of the kerfed part
TEAM BUILT FOR DECIBELS
s10 blazer
subs:2 Addictive Audio
amp:Addictive Audio 500.1
batts:Vital Power vp1500(front), vp2000(rear)
  • 2 months later...
can someone give an example?
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
If your kerf is 12" long then 6" of it is added to port length.
Or 9/4.5, 8/4, etc etc etc.. you know, that thing called "half"
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1619 Guests (See full list)
