awall1022 Posted July 17, 2011 Report Posted July 17, 2011 So along with my Jonah Lomu Amp that i bought from my uncle he gave me a Stinger Fuse block. It has 3 0gauge inputs and 4 4gauge outputs. I plan to run 2 amps from this. what would be the best suggestions. 1 amps will be the Fusion Jonah Lomu FJL-1211D runnin it on 2 ohms for 1250w RMS. And an American Pro Bass machine 300 watt. i my plan is to set my system up like this Since i listen to everything i will have 2 10''s for the rock and 1 15'' for rap. i plan to wire the remote for each amp to switches as well as the fan board for the amps. im doin this so i can switch subs when i wish. Is this a bad idea? and would i be able to do 1 run of 0g to the fuse block then 2 4g runs out to the amps? thanks for the input in advance lifted trucks gorgeous sluts a pretty face and slammin bass My current Set up Car less I Do Ported Box designs/cutsheets with 3d google sketchup model just PM i would really want an in-depth guide Just flip the fucking thing over
Supercharged DCs Posted July 17, 2011 Report Posted July 17, 2011 Do you plan to run both sized woofers together? If so, put them in separate boxes. I have seen people use various sized woofers to play different frequencies, with the larger woofer picking up the low range and the smaller one picking up the higher notes... But you do know a 15 can play Rock just as well as a 10, right? It's all in the install man... Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
awall1022 Posted July 17, 2011 Author Report Posted July 17, 2011 i plan to have them in different boxes. and i plan to run the subs seperately. my plan is to have the 15 tuned for the really low stuff and the 10''s for the higher like the kicks for rock. so my biggest question is runnin 1 0g input to the block and 2 4g outputs would be ok and if wiring the remote wires for the amps to switches would be ok? or would it harm the amps having them turned on and off randomly? lifted trucks gorgeous sluts a pretty face and slammin bass My current Set up Car less I Do Ported Box designs/cutsheets with 3d google sketchup model just PM i would really want an in-depth guide Just flip the fucking thing over
awall1022 Posted July 20, 2011 Author Report Posted July 20, 2011 any suggestions im gonna order some 1/0 this week i want to know if this would be bad for my electrical lifted trucks gorgeous sluts a pretty face and slammin bass My current Set up Car less I Do Ported Box designs/cutsheets with 3d google sketchup model just PM i would really want an in-depth guide Just flip the fucking thing over
jokerklown Posted July 20, 2011 Report Posted July 20, 2011 why not just run both amps and all 3 subs at the same time?
tctdh11 Posted July 20, 2011 Report Posted July 20, 2011 ^ X2 TEAM DC www.dcsoundlab.com 2003 Tiburon GT V6 6 Speed Ported Clam 6 12" DC Audio XL M2's 2 American Bass 1100.1 1 American Bass 350.4 3 D3100, 1 D975, 3 D925 Second Skin Damp Pro and Spectrum. About 75% done 153.6 Sealed on dash at 34hz My OLD Build Log New Build Log.. DC XL M2 4th Order in my Tiburon
