TWO DC AUDIO PAI 3000.1 & A PAI-120.4
mmmmmm PM me here or on face book, i could be interested
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Okay for the guys looking for more information on these amplifiers. Here it is straight from the manual.
Double Sided Through Hole Epoxy PCB
1 Ohm Stable Circuit
Daisy Chain Through Output RCA
Two Amp Linkable Function: Output Master And Input Slave
24db/Oct Variable Crossover
Multi Way Protection Circuitry (thermal/over current/speaker short/speaker dc protection)
RCA Line Input
Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero Gauge Power Supply Connectors
Tested Voltage & THD: 14.4V & Less Than 1% THD
Operating Voltage: DC 10V-16V Power Input
Wired Remote Controller
any specs on what they will do strapped? or also on a 16volt system?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
These amps are beasts. I personaly have one running 2 12" DC lvl 4 XLs @ .5 daily. STRAIGHT BEASTS. I've acctully been looking for a secound DC PAI 3000.1 so I can run one to each sub. But it seems every time one is for sale.. Im broke lol. Anyways these where amps made for Project Audio Innovations (Hints the PAI) which where shipped over seas iirc. And the remaing amps in the batch where sold state side. There was a clamp test thread somewhere compareing these amps to the SA ones, can't seem to find it tho.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Where is the build house on these?
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
