I recently installed a mechman alt WTF!!! And whated to know what is the volts cold that people run on there batterys. I have one 5100 and a 3400 in the trunk. Big 3 did. I'm currently charging cold at 15.3 is that to high for my batterys even tho I see alot of people running that high?
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
I got views but no replays come on guys.
MechMan 220a Alt
DC 5K
Kicker 650.4
Pioneer DEH-P7200HD
no 15.3 is fine, some people even run higher, so says the guys in one of the threads i responded to, he said he has a friend running 15.7V. i wouldnt up it unless i researched more.
chevrolet all day er day.
'81 camaro z28 performance
'03 silverado ext cab show and go
Need more input?
MechMan 220a Alt
DC 5K
Kicker 650.4
Pioneer DEH-P7200HD
Generally under 15 is fine. A few people say under 16.
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
are we talking charging battery voltage or alternator output voltage?
Where talking alt output voltage. When its hot it drops down under 15volts.
MechMan 220a Alt
DC 5K
Kicker 650.4
Pioneer DEH-P7200HD
ya people run 15.7 alt output, 14.7 volts is charging voltage of your battery.. soo you could probably scope up your settings bit
leave it alone. cold start that is fine once your car warms up and alt warms up specifically its output voltage will drop to safe levels.
Did the alt come with AVBM harness? if so just keep an eye on your voltage once car is hot that while driving you don't go over 14.8v
If it does just make fine adjustments down until around 2000rpm your at 14.8v hot. you can mess your batteries up if you charge them higher than what xs recommends for longer than 5min.
:turkey:
Edited by crunkjuice1
