michigancapri92 Posted July 19, 2011 Report Posted July 19, 2011 ok so is it normal for me to still here subtle music coming from my speakers when i unplug all my RCA's i still hear music through my speakers? along with hissing ... Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
tonedeaf Posted July 19, 2011 Report Posted July 19, 2011 Are you tied into the factory amp? Did you hook up the system? Some retards use jump cables basically that just clamp onto the stock wiring which causes them to run from the HU amp and your amp.
michigancapri92 Posted July 19, 2011 Author Report Posted July 19, 2011 not using the radio wire only using the RCA's from HU to the AMP Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
tonedeaf Posted July 19, 2011 Report Posted July 19, 2011 Not sure if you can get any signal cross if you run the RCAs next to the power wire or not.
tlee2 Posted July 19, 2011 Report Posted July 19, 2011 Try a different ground 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
