so im getting a new car and the back seat is going to fold down and im gunna have 2 15's firing into the cabin. they are gunna be 2 15" Fi Q's on 2 fosgate t10001bd's. what type of electrical am i going to need? alternator, wiring, batts, etc....anyone that has done it lemme know.
thanks!
12" fi q
rf t10001
naw mean
thanks!
2 runs of 0 gauge for sure. yellow top up front and 1 or 2 kinetik batts in the rear. the big 3 will help out alot too. these upgrades are needed to keep the voltage up. thats what its all about. ;)
alright so 2 runs for 1/0, big 3 for sure, a yellow top up front and a couple kinetiks in back...
how big of a kinetik should i get?
also, should i look into a ho alt? its going in a beemer, most likely a 325is
12" fi q
rf t10001
naw mean
Posted (edited)
get 1 kinetik hc2400 out back and youll be set. and a bigger alt definitely will help.
aight cool thanks bro. btw do you have any idea how much a kinetik 2400 costs? i hope not too much
Edited by kevinb721
12" fi q
rf t10001
naw mean
you really don't need two runs of 1/0 ....... one run would be fine, two runs i'd only do if you planned on adding another 3000rms of power. as for battery with that amp, go onto www.kinetikaudio.com and see what they recommend. i'm not saying the guys have sterred you wrong but i don't know your pockets either so let's start from there bro and seeing you only meantioned one RF T10001bd then that one yellowtop underhood should do it.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
my bad if u thought only 1 t10001....im gunna be having 2 of them
12" fi q
rf t10001
naw mean
well two runs would be great then. as for the batteries, i'd do one underhood and one in the back and upgrade that alt ............ you should be good to go.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Let me put it this way...there is no such thing as overkill when it comes to your electrical system. Two runs of wire 1 kinetik up front, 1 in the rear and the biggest alt you can find/afford!
Scientia est Vox
SMD SUPER BUYER/SELLER
