MrGeo Posted July 22, 2011 Report Posted July 22, 2011 my buddy Brett bought the truck with this JVC headunit in it and it has been working since november, but recently the audio would just cut out and all that would play is bass. Over the last week it has been , but now it only plays bass. Can anyone tell me if there is a known fix for this or if he just needs to buy a new headunit? I took it out the dash and there's no noticeable loose connections, also, the speakers were recently replaced with AudioPipe 6.5"s. Thanks for your help! Here's a video: http://www.youtube.com/watch?v=wOa62k-KU8A http://www.youtube.com/mrgeo20-Bagged '98 S10-Lowered '96 Ranger -'01 Civic EX Boosted -'99 Sierra, under construction
bass_stalker Posted July 22, 2011 Report Posted July 22, 2011 what source is he using? JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
MrGeo Posted July 22, 2011 Author Report Posted July 22, 2011 what source is he using? as in Radio, CD, or AUX? none of them work. http://www.youtube.com/mrgeo20-Bagged '98 S10-Lowered '96 Ranger -'01 Civic EX Boosted -'99 Sierra, under construction
6berry Posted July 22, 2011 Report Posted July 22, 2011 im assuming the mids and highs are powered by the headunit. try disconnecting the speaker wire at the headunit and put a dmm to the wires to make sure they have resistance from the speakers. if they show resistance then its probably the headunit, if not then its probably a loose connection somewhere down the line 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
bass_stalker Posted July 22, 2011 Report Posted July 22, 2011 i would say if it was the auxiliary it was a short in his cord or something. did he mess with any of the settings in the radio that change the outputs to low pass. do you have any other radios he can try? EDIT: i was assuming he had a mids amp and a higs amp JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
MrGeo Posted July 22, 2011 Author Report Posted July 22, 2011 sorry, i should have said that the 6.5"s are being powered off of the headunit. and thanks 6berry, we will try it. http://www.youtube.com/mrgeo20-Bagged '98 S10-Lowered '96 Ranger -'01 Civic EX Boosted -'99 Sierra, under construction
