Nightshade 18 in 4.5 cubes after displacement. port through the rear deck.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
The set up C-fizzy described is basically exactly what I did... My box is just a bit bigger.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
How big is your box? and how much power are you giving it?
under construction
u hate c-fizzy?
I can go upto 7 cubes with sub up port back on driver side ... I was planning on a 5 cube box after porting ...or just 6 cubes with aero and sub displacement tuned to 36hz
would be putting this on a AP30001D adjusted to 2500rms
hopeful noob
Posted (edited)
Just remember, you'll need to get a dual 4 sub and wire down to 2 ohms since that (those) amplifier(s) isn't/aren't 1 ohm stable.
Basically, the 3000 is two 1500s strapped. So when you wire to 2 ohms, each 1500 is seeing 1 ohm.
Just in case you didn't already know this. Don't want you buying an amp and instantly smoking it!
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
my advice to you being that i have a 98 neon and know what a neons trunk looks like is to do 2 12s trunk sealed facing the cab u would do better numbers then trying to stuff an 18 in the trunk
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
